Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Buzzing sound from power conditioner
Thread Tools
Old 17th September 2021, 12:27 PM   #41
NareshBrd is offline NareshBrd  India
It may be buzzing due to load.
Disconnect the load, and check.
The thermal relay, if there is one inside, can also be a noise source.
Old 17th September 2021, 02:48 PM   #42
mwilson is offline mwilson  United States
Thanks. I'm back on the road and will try these when I return, late next week. Wishing you all a great weekend, and thank you once again for all the help!
Old 17th September 2021, 04:23 PM   #43
seppstefano is offline seppstefano  Italy
seppstefano's Avatar
Originally Posted by jean-paul View Post
...... just when I thought my German made brand new isolation medical transformer was expensive with 75 Euro
A couple of days ago I received a small carton with three small isolation medical transformers from Sedlbauer AG for my ever-going mains unit project. Just curious to know whether we selected the same brand?
Old 17th September 2021, 04:45 PM   #44
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
Mine is a Noratel IMED150. A ready made certified medical device in casing so with switch, fuse etc. Left over from project.
It's only audio. Member of the non modular PCB design committee.
Old 17th September 2021, 04:56 PM   #45
Thanks for sharing, mine is Ringkerntrafo Transformator 300VA 2x115V 2x115V 230V Sedlbauer RTO-825054
Old 17th September 2021, 05:28 PM   #46
jean-paul's Avatar
62 euro is not bad. An isolation transformer ia a very good upgrade for audio sources. IMO it is an obstacle but when I take it out of the chain the result is less good. Using it makes more of a difference than using mains filters. I use both.
Old 18th September 2021, 09:39 AM   #47
Absolutely, years ago I used one for all digital-related sources (including my separate DAC), another one for analog (preamp, tuner). Power amp went (and goes) directly to mains, through a parallel line filter.
Now I'm going to further separate DAC from devices operating only at digital level (yes I still happen to have a CD spinner ).
So, that's why three small trafos, way oversized for the VA declared requirements. Less load and hopefully less mutual interference.
And you can wire to have balanced mains feeding your unit.
Old 5th November 2021, 07:26 AM   #48
jean-paul's Avatar
Originally Posted by seppstefano View Post
Got hold of Imed 1000's for 100 a piece. With electronic soft start, test button etc. I also could have the 2000 but these hum extremely.
Old 5th November 2021, 09:37 AM   #49
It seems you found a really good deal!
I installed two out of the three trafo I bought for my diy unit and so far I'm glad they're dead silent and the increased mains separation improved the pleasure of listening
Old 5th November 2021, 10:24 AM   #50
jean-paul's Avatar
Will try the Imed1000 this weekend. It hums slightly mechanically (as usual with 1000 kVA...) but apart from that it is a ready built medical device so everything is well designed. These are custom built in a larger 19" casing for a certain brand medical gear. What surprised me is the very loud humming of the 2000 version. That one is absolutely unusable for audio when placed in the same room.
Buzzing sound from power conditionerHide this!Advertise here!
Thread Tools
Review of AC Power Filter Power Conditioner bought online andy2 The Lounge 2 14th July 2018 10:18 PM
power cord upgrades, and power conditioner ksporry Power Supplies 112 5th January 2015 02:37 PM
Power conditioner from a 5KVA power transformer? AllenB Power Supplies 37 11th September 2014 08:04 PM
buzzing and pop sound when fender power amp is turned on zaboomafoo Everything Else 0 27th August 2004 06:12 PM
Power Conditioner Schematics sandro Everything Else 0 11th February 2002 02:48 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
