Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Zip cord for speaker test
Thread Tools
Old 12th June 2021, 12:06 PM   #251
planet IX is offline planet IX  Germany
planet IX's Avatar
Okay, I will let you know when I have it
Boris
Old 17th June 2021, 07:15 AM   #252
planet IX's Avatar
Hans, I received the new 4mm zip cord cable.
I purchased 10m and cut it in half, so 5m has:
275pF, 0,065Ohms, 27H
(for R and L the ends were connected)
Regards, Boris
Old 17th June 2021, 10:04 AM   #253
planet IX's Avatar
Edit: I just measured the length - I ordered 10m and received 8m...
It's therefore 2x 4m ...
Old 17th June 2021, 01:06 PM   #254
Hans Polak is offline Hans Polak  Netherlands
What a fraud to sell 10m but only deliver 8m.
However, I think you inductance must be 2.7uF instead of 27UF.
Hans
Old 17th June 2021, 07:02 PM   #255
planet IX's Avatar
OK, I will measure it again next monday, I probably a mistake.
It was hot and terribly humid today, not good for work...
Boris
Old 22nd June 2021, 09:43 AM   #256
planet IX's Avatar
Hans, here are my new measurements:
C= 270pF
R= 0,045Ohm
L= 3,8H
Boris
Old 24th June 2021, 02:56 AM   #257
Ill come with a fresh calculation for you.
Still a bit puzzled why the inductance value was so far off in your first attempt ?
But this time everything seems perfectly o.k.
Hans
Old 24th June 2021, 07:36 AM   #258
planet IX's Avatar
I have an old but precise Phillips RCL meter (4-wire measurement).
It has settings for Cs/ Ls and Cp/ Lp (series/ parallel / capacitance/ inductance).
The last time I accidentally choose Lp instead of Ls, hence the higher value.
Old 24th June 2021, 07:03 PM   #259
Hi Boris,
Dividing the cable in 4 equal section, at the 3 points intermediate points, you will need to connect in series at each point between the two conductors:
0.45nH >5 Amp
8R >20Watt low inductance
35nF polypropylene >40Volt AC
This will give you a cable with Zo=6R in the audio range.
Anxious to hear what this will bring to your sound perception.
Hans
Old 25th June 2021, 07:45 AM   #260
planet IX's Avatar
Thanks a lot, Hans. I will try it out as soon as I have the parts.
I thing I will make the 0,45nH Inductor by winding a couple of turns of 1,5mm solid wire on a stick. I'm exited about what it will bring...
Boris
Zip cord for speaker testHide this!Advertise here!
Thread Tools
FS: power cord MIT Z-cord indaco Swap Meet 0 6th September 2020 05:27 PM
Dual coax zip cord style cable percy Parts 2 13th May 2014 05:40 PM
Don't zip PDF files jwb Everything Else 1 23rd March 2003 05:53 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
