Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Zip cord for speaker test
Thread Tools
Old 3rd June 2021, 07:22 PM   #221
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
Originally Posted by Hans Polak View Post
3) My emulation. Also very 3 dimensional, less wooly and warm with better articulation of voices, but sometimes a bit too analytical.
Never owed a MIT but had plenty of Transparent stuff which is broadly similar. By memory the sound had a very focused soundstage and deep and convincing bass. Not a whole lot of sparkle, but generally pleasant. Eventually went towards more revealing and simpler wire, the Transparent was nice, but definitely not natural.
Many other factors apart from the boxes contribute towards their house sound. The cables were very heavy and felt very well damped mechanically, which may have been partially responsible for the slightly dead and remote sound.
Old 4th June 2021, 04:19 AM   #222
1audio is offline 1audio  United States
Demian,
Did you already have the opportunity to go trough your cable pile in search of MIT LS cables.
If so, i would be interested to get the type numbers to see whether further investigation makes sense.
Hans
No, the cables are in storage about an hours drive from here. Its a large pile. it will be at least a week.
If you are using Quads there is an easy test for difference that may work. It was used by Quad on the factory floor for testing production- Line up 2 quads side by side. Connect one out of phase to a mono source. There should be a distinct deep null across the entire audio range if they match. it would be interesting to try this with different cables and listed for the differences. I need to get my audio system working again. Been too busy during the pandemic.
Demian Martin
Product Design Services
Old 4th June 2021, 01:10 PM   #223
Hans Polak is offline Hans Polak  Netherlands
I can’t confirm that Transparant and MIT are similar, outside the fact that MIT LS cables range from a few hundred to one hundred thousand dollars, like a Fiat 500 to a Ferrari, all from the same company.
So there’s a large scala to choose from and comparing should be done on base of a specific type number and not on the name of the manufacturer.
The last thing that applies to my subjective experience in my audio set is that the sound is not at all slightly dead and remote, but instead places you in the front rows with a fantastic sense of “you are there”.
Hans
Old 5th June 2021, 05:51 PM   #224
I have replaced the cheap polyester caps by styroflex ones.
Sound is now even more direct, without the analytical touch.
To my feeling I have improved on the MIT MH-770.
Hans
Old 10th June 2021, 08:22 AM   #225
It amazes me that DIYers on this forum are spending large sums on all sorts of nice project in search of the holy sound grail, but when the option is there to possibly improve sound with very low cost manipulated LS cables, there is no animo.
And believe me, blind listening tests are not needed to hear the difference, it is so obvious, at least in my case.
Although no satisfactory physical explanations exists and although many people are prejudiced that cables cannot make a difference, wouldn’t it be a challenge to give it a try and leave your comfortzone for once.
All you need are 6 resistors, 6 coils and 6 caps plus 2*2.5 meters 4mm^2 zip cord.
Hans
Old 10th June 2021, 08:30 AM   #226
peufeu is offline peufeu  France
peufeu's Avatar
Does anyone know what's inside the mystery boxes on this MIT cable?
Old 10th June 2021, 08:52 AM   #227
danny_66 is offline danny_66  Belgium
danny_66's Avatar
Hi Hans,
how do you calculate the values of the LCR ?
My RefSpeaker v2
Old 10th June 2021, 10:03 AM   #228
A few things can be said to that question:
1) how much can be hidden as a mystery that a VNA cannot decipher ?
See Zip cord for speaker test,
Zo is almost identical over the whole Frequency Range.
2) this MIT MH-770 cable was conceived long ago, but looking at MIT’s many patents, according to their latest one, they now do like what I did, see image below, although it may still be that they use several cord diameters in parallel in their very thick cables, where I used only one zip cord.
Hans
Old 10th June 2021, 10:11 AM   #229
peufeu's Avatar
Interesting.
Old 10th June 2021, 10:27 AM   #230
planet IX is offline planet IX  Germany
planet IX's Avatar
I would gladly repeat this experiment, but my speaker cables need to be a bit longer.
So should I repeat the network any 0,625 meters?
Zip cord for speaker testHide this!Advertise here!
Thread Tools
FS: power cord MIT Z-cord indaco Swap Meet 0 6th September 2020 05:27 PM
Dual coax zip cord style cable percy Parts 2 13th May 2014 05:40 PM
Don't zip PDF files jwb Everything Else 1 23rd March 2003 05:53 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 13.64%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
