Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Zip cord for speaker test
Thread Tools
Old 9th May 2021, 07:11 PM   #151
jneutron is offline jneutron  United States
jneutron's Avatar
Ah, thank you, you are keeping me on my toes....
I will explain better.
The wire being used is I believe a 1kV rated twisted pair, so the insulation is fairly thick. This brings the impedance up, I am guessing roughly 150 ohms.
You are correct, I did mention 50 ohm coax. My intent at first was to use 5 paralleled 50 ohm coaxial cables with a effective impedance of 10 ohms. That would drop any wire settling time into a 1 or 2 ohm load (resistive) down into the single digit microsecond range.
900 runs of coax is a lot. So I researched triax, the intent is to use the two shield braids as the coaxial run. The inner core wire will not be used to carry current, it probably won't even be connected. It's the outer two braids that have an impedance of 10 ohms between them.
But thanks for picking that up. If I had been relying on the core impedance, I'd have been 50% off the mark...and totally sunk..
But now you have me thinking...If I use the inner shield as ground reference, the outer as the hot (+/- 20 volts), then I could use that 75 ohm core wire as a voltage readback from the magnet...hmmm. I'll be thinking about whether that buys me anything..
Thanks again,
John
I hate all these smart gadgets..I refuse to buy things that are smarter than me. I've made a list of those things... Cabbage just made the list.
Old 9th May 2021, 07:44 PM   #152
RJM1 is offline RJM1  United States
Thanks for clearing that up. I knew I must have been missing something.
Old 11th May 2021, 04:28 PM   #153
Hans Polak is offline Hans Polak  Netherlands
Here are resp. the Char. Imp, the Capacity open ended and Inductance with end shorted for a 3 meter 9222 Belden Triax cable measured between the two outer shielding layers.
Doesn't look like the ideal speaker connection to me in this form.
Hans
Old 11th May 2021, 06:55 PM   #154
jneutron's Avatar
I'm not exactly sure what an ideal speaker cable would look like in that form.
John
Oh, and thank you for that test result.
Old 11th May 2021, 08:59 PM   #155
John,
Neither did I, because so far I was never interested in the so called superior technical aspects of a speaker cable and only trusted my ears.
But after having recently measured my own LS cable, I was astonished how close the Char. Impedance matched the impedance of my speakers.
Perhaps I fool myself, but to my ears the sound of my cable is far superior to zip cord or whatever other simple type of connection.
So it could be that impedance matching is much more important than I ever thought.
In that case this triax cable does not have the right impedance form.
Hans
Old 12th May 2021, 08:01 PM   #156
As mentioned already to George, I found an error in the capacity calculation of the used software.
Will redo the measurements once corrected.
Hans
Old 12th May 2021, 08:12 PM   #157
gpapag is offline gpapag  Greece
gpapag's Avatar
As mentioned already to Hans, this is the fate of pioneers
George
["Second Law is a bitch." - SY]
["I insist on respecting the means of the average person working in their garage/basement." -Scott Wurcer]
Old 13th May 2021, 07:46 PM   #158
Luckily I can confirm that the calculations I used for finding the Char. Impedance were correct after all because I used the impedance measurement of the used FRA Imp Viewer.
However the images showing capacitances are wrong most of the time, because of a simplified calculation that may give erroneous results in some cases.
But the impedance calculations are fully correct, so all the images relating to impedance and Char Impedance in this thread still hold.
Pfffff.....
Hans
Old 14th May 2021, 07:05 AM   #159
gpapag's Avatar
Now you may enjoy a drink
George
Old 14th May 2021, 02:39 PM   #160
Still frustrating is that I couldnít convince the author of the program of his wrong calculation.
When Z = A + JB and you want to calculate the capacitance, then
1/jwC= A + jB
His aproach is in that case to say jwC = 1/jB or C = 1/wB
Because j are in the numerator and in the denominator, this is wrong.
Correct is: jwC = Im( 1/(A + jB)
Solving this gives jwC = jB/(A^2 + B^2)
or C = [B/(A^2 + B^2)] / w
When A is very small, both formulas give equal results with 1/Bw.
So sometimes the result is o.k. but most of the time itís not.
Hans
Zip cord for speaker testHide this!Advertise here!
Thread Tools
FS: power cord MIT Z-cord indaco Swap Meet 0 6th September 2020 05:27 PM
Dual coax zip cord style cable percy Parts 2 13th May 2014 05:40 PM
Don't zip PDF files jwb Everything Else 1 23rd March 2003 05:53 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
