Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Bluetooth on Vintage amps.
Old 22nd May 2020, 03:11 AM   #11
redrooster is offline redrooster  Australia
redrooster's Avatar
I'm fairly sure the BT module works off 3.3v so that's 1.7v headroom for any voltage drop. Doing this will be pretty straight forward I would think?
Old 22nd May 2020, 03:45 AM   #12
anatech is offline anatech  Canada
anatech's Avatar
Well, if it has a USB jack, that's 5 VDC.
"Just because you can, doesn't mean you should" my Wife
Old 22nd May 2020, 04:16 AM   #13
redrooster's Avatar
At the moment I'm using the USB-3 on my computer for charging the BT transmitter and a 5vDC 850ma output phone charger plugged into the power strip on the BT receiver end. Its all messy and complicated but the quality is crazy good in the end. lol
Old 22nd May 2020, 04:23 AM   #14
anatech's Avatar
Well, a 3.3 VDC regulator is pretty easy. I don't see any problem with powering this thing inside your amp.
-Chris
Old 22nd May 2020, 04:31 AM   #15
redrooster's Avatar
I'll get around to doing this when I've got the time, I have two Yamaha amps to fix in the meantime and a mobility scooter as well. Thanks for the advice Chris, it's appreciated. If it wasn't for this online help I wouldnt get very far at all?
Old 22nd May 2020, 05:19 AM   #16
anatech's Avatar
When you have time, what model # of Yamaha amplifiers?
Old 23rd May 2020, 02:05 AM   #17
redrooster's Avatar
One is an RX-497 stereo and the other is an RX-V430 5.1, the RX-497 had a failed film capacitor in the turn-on circuit but I popped/fried the DTC-144ESA transistor when checking things out? so I'm waiting for a replacement in the mail. The other Yammy has the same kind of problem. No turn on or display? I also have a recently acquired Sansui G-4700 that I'm going to recap and clean up the boards. It still sounds great, just a bit boomy on the bass.
Old 23rd May 2020, 04:30 AM   #18
anatech's Avatar
Hi redrooster,
Okay, small receivers. Fun to work on and rewarding when you fix them.
Look for the AC detect cap on the RX-V430. It's often a low value electrolytic (like 1uF) in the power supply area, or near the CPU.
-Chris
Old 25th May 2020, 11:06 AM   #19
redrooster's Avatar
Oh good stuff, thanks for that Chris. I'll check it out? A guy I know works for a roadside cleanup company, he finds lots of amplifiers for me to play with.
Old 25th May 2020, 01:29 PM   #20
Pano is offline Pano  United States
Pano's Avatar
Red please do NOT quote the entire post just above yours. This is mentioned in the Rules section. Use the Reply button not the Quote button.
I have cleaned up all the over-quotes.
Bluetooth on Vintage amps.Hide this!Advertise here!
Bluetooth/Wi Fi for Vintage Amp. redrooster Analog Line Level 13 15th January 2020 03:23 AM
Want a good APT-X Bluetooth Module for my D-Class Amps mstang1988 Digital Source 4 9th October 2018 03:37 AM
Bluetooth for vintage stereo marcjero Car Audio 4 8th August 2018 08:56 PM
Secondary output from Dayton Bluetooth Amps? seantkezm Class D 0 8th September 2017 03:23 PM
Vintage Bluetooth Radio Easy Conversion - Noob javy Everything Else 7 24th September 2014 04:29 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
