Hello all again and I wish you a good and prosperous year 2020!
I have a new test (again), 2 files recorded through various opamps and would like to ask you if you can hear a difference. The music samples are in 96/24 format, encoded as 32-bit wav. The download link is
Dropbox - boston.zip - Simplify your life
You do not need to sign-up to dropbox, just click on the arrow top right and select Direct Download. Do not try to play wav files from dropbox directly, it is impossible, as they are packed in a boston.zip file.
As always, ABX result would be highly appreciated and regarded, but is not a necessary condition.
Enjoy!
Enjoy!
Some listening -
Code:
foo_abx 2.0.2 report
foobar2000 v1.4.8
2020-01-09 08:03:24
File A: boston11.wav
SHA1: 5ae8849c8ce3bda8321ffb3f16ad9e797bf736f3
File B: boston22.wav
SHA1: 4955964da2691ab762acf72f25416a7431748109
Output:
ASIO : Creative Sound Blaster ASIO
Crossfading: NO
08:03:24 : Test started.
08:03:50 : 01/01
08:04:16 : 02/02
08:04:29 : 02/03
08:04:47 : 03/04
08:05:05 : 04/05
08:05:38 : 05/06
08:05:58 : 06/07
08:06:18 : 07/08
08:06:30 : 07/09
08:06:42 : 07/10
08:06:42 : Test finished.
Total: 7/10
Probability that you were guessing: 17.2%
-- signature --
be1c42344ce9725cf5ba40ebd94fe706a6da2662
Code:
foobar2000 v1.4.8
2020-01-09 21:24:48
Output:
Crossfading: NO
21:24:48 : Test started.
21:25:09 : 01/01
21:25:19 : 01/02
21:25:29 : 01/03
21:25:49 : 02/04
21:26:01 : 03/05
21:26:20 : 03/06
21:26:34 : 04/07
21:26:43 : 05/08
21:26:55 : 06/09
21:27:13 : 07/10
21:27:13 : Test finished.
Total: 7/10
-- signature --
b6514321df42df307fdfd400195430bbd81423f3
So I finally had another re-listening session, I am not going to be too analytical or peeking at spectrograms etc. but saying that I think am hearing a difference (no ABX though), at least file B seems to sound "meatier" somewhere in the mids while A sounded "cleaner", the first 15 seconds are most revealing.
Pavel, are you ready yet telling something more about the two file samples?
Interesting comment, and yes, I am going to disclose it.
Both samples were recorded with
Audio Buffer in english
the version described at the bottom of the page, with output series resistor R10 = 50ohm.
The differences:
1) Boston11 has TL061 in the left channel and OP27 in the right channel.
2) Boston22 has AD744 in both channels.
The channel with TL061 is about 6dB noisier than the channels with OP27 and AD744. The OP27 channel almost does not differ from the AD744 channels. Integral values of samples in all channels do not differ (peak, avg etc.), we may say they are identical. Direct subtraction shows difference between TL061 and AD744 channels, maybe a slightly longer delay of TL061 (due to its lower GBW) is reponsible for it. The difference in delay of TL061 vs. AD744 is only about 200ns.
- General Interest
- Everything Else
- Can you hear a difference between opamps in 96/24 samples?
