What does that have to do with results of DBT I mentioned?Pavel can perceive the difference on the 3 very low distortion preamps, however I do not find any of them to be poorly designed.
Must you attack people so often on forum?It actually is good for you if you can not hear a difference, no incentive to spend on more expensive parts like the AD797. Better yet when you find a cheaper parts like the TL072 to sound the same. Too bad for those who do hear.
<snip>
......, the subjective version is just that, no level matching, no visual bias controlled, no memory span compensation and no room mode accounted for. The level matched version was done by volt meter at the speaker terminal when amps were switched.
As for Markw4's secret listening test method, will you be asking the same?
I was just asking for the detailed description of your listening tests; if you've never done any serious, rigorous controlled listening test, just say so.
In your biased opinion, of course.You lead miles ahead by examples.
I'm just asking, why do you care?I was just asking for the detailed description of your listening tests; if you've never done any serious, rigorous controlled listening test, just say so.
<snip>
I am interested in your approach to listening tests.
In my opinion, you are posting things insulting the years of diligent work in improving audio by people like Scott Wurcer, Pavel Macura, Nelson Pass, Earl Geddes and others.... I'm posting things that can undercut your audio business?
As I've stated, "In your biased opinion, of course." which you are entitled to. If I post what you are in my opinion, it will get reported to the forum authority so I won't.In my opinion,
Cable lifts! the final step to audiophile nirvana?
I took the two files and loaded them up in Audacity... I was not able to time align them well enough to get a null test showing me the difference. The tempo is off by a tiny bit and the files are different sizes... which might actually be what people heard.
- General Interest
- Everything Else
- Can you hear a difference between 2 solid state preamps?
