Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Circuit for one legged capacitor ?
Old 16th August 2019, 04:54 PM   #21
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
methinks that you actually need half circuit
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 16th August 2019, 04:58 PM   #22
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
Originally Posted by w5jag View Post
So how did the other 999 test? Good or bad?
The others were fine.
Good old cheap Chinese caps.....
PCBCAD51 download or CDROM October 2019 version out now ..https://www.murtonpikesystems.co.uk
Old 17th August 2019, 04:47 PM   #23
RJM1 is offline RJM1  United States
@rayma
Back in the early 90's I worked for a video projector manufacturer and they were having quality problems with shorts and opens in their motherboards. They asked their supplier to electrically test the boards before shopping (an added expense). We received a batch of 100 boards and a report that 91 had passed. They shipped us 100 boards and after populating and testing the boards we found that they were right. 9 were bad.
Old 17th August 2019, 08:10 PM   #24
rayma is online now rayma  United States
Why did they send you the bad boards? For a while years ago, I worked for Tracor Northern,
and they had lots of multilayer pcbs with internal shorts.
Old 17th August 2019, 09:28 PM   #25
JMFahey is online now JMFahey  Argentina
JMFahey's Avatar
S.O.B.s
Why did they not only ship but charge for the bad on es?
100 times worse: not identifying the bad ones thay made you WESTE time, money, effort and components on the bad ones ... not mentioning the bad ones damaged or at least blocked selling 9 fully finished products.
CRAZY!!!!
Design/make/service musical stuff in Buenos Aires, Argentina, since 1969.
Old 22nd August 2019, 02:31 PM   #26
Fast Eddie D is offline Fast Eddie D  United States
Originally Posted by jan.didden View Post
Probably makes a nice WiFi antenna as well!
Jan
Some capacitors do make good antennas. I forgot to solder one leg of a capacitor once. The circuit worked with reduced gain (it was the electrolytic in a feedback circuit), but it was picking up multiple radio stations at one time. Poking around the circuit with my finger, I noticed that if I touched one capacitor the noise got way louder. I fixed the one solder joint and it worked as intended.
I also learned to connect the capacitor to the lower impedance leg of the circuit in a filter circuit. Example if you have a capacitor and resistor in series, ground the capacitor if one leg of the circuit is grounded. If the components go between the output and inverting input, then the capacitor get connected to the output.
Old 22nd August 2019, 02:38 PM   #27
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Yes sound advice. Also in case of a rolled film cap, where you can identify the lead to the outside of the roll, connect that to ground to shield the internals.
Jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 22nd August 2019, 02:44 PM   #28
Tubelab_com is online now Tubelab_com  United States
Tubelab_com's Avatar
Probably makes a nice WiFi antenna as well!.....Some capacitors do make good antennas.
It might make a good WiFi or GPS antenna if you had the means to trim the lead length just right.
I spent several years in cell phone design. We were putting together a few prototype phones for field testing and we hadn't received the GPS patch antennas from the vendor.
The plan was to test without GPS, but I took a couple of paper clips cut them in half to form a "J" shape and trimmed them to match the correct frequency and impedance on a network analyzer. I stuffed them into two phones and we went about our testing.
We did some basic GPS testing on the two phones that had the paper clips, then replaced them and fitted the remaining phones with the proper antennas, then did the usual GPS testing. It seems that the bent paper clip had outperformed the proper GPS antenna by a pretty good margin. This was verified with more paper clips.
The final shipping phone got a better ceramic patch antenna, that did work better than the paper clip when held in the hand. That's where the paper clip failed to keep up.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 22nd August 2019, 02:49 PM   #29
amplidude is offline amplidude  Denmark
It's not nice to make fun of a handicapped capacitors, it might get depressed, but since its one legged it might be usefull in a pirate FM transmitter.
Old 22nd August 2019, 02:55 PM   #30
Does bipolar caps suffer from mental illness?
Circuit for one legged capacitor ?Hide this!Advertise here!
short circuit where capacitor sat ? zoazim Power Supplies 4 6th October 2018 12:14 PM
3 Legged Inductors istari knight Multi-Way 13 16th May 2013 04:12 PM
Y1 and Y2 Capacitor in SMSP circuit Sara001 Power Supplies 1 4th June 2012 01:42 PM
four legged capacitors, where to get? Elbert Solid State 6 2nd January 2011 06:46 PM
How to fit a 4 legged Crystal into Kwak Clock ? Will Digital Source 5 20th November 2004 03:40 PM
Copyright ©1999-2019 diyAudio
