Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Convert mm to inches - easy to remember!!
Old 18th July 2019, 10:45 AM   #71
levistubby is online now levistubby  United Kingdom
It's certainly not unusual to have rules calibrated 10ths of an inch. I have a 12" stainless steel rule date stamped 1943 that has four scales.
1. 16ths - 32nds - 64ths.
2. 12ths - 24ths - 48ths.
3. 10ths - 20ths - 50ths.
4. cms - mm - 1/2mm.
Those combinations on one rule are a bit unusual I think.
I also have a 12" Chesterman No.412D rule dated 1961. It also has four scales one of which is 12ths - 24ths - 48ths - 96ths on an inch. It is also marked "Standard at 68F"!
Old 18th July 2019, 03:27 PM   #72
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Yes mine was steel as well and had only tenths. I know that scales often have the decimal inches but I figured they just needed to fill up one last side.
Old 18th July 2019, 03:38 PM   #73
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
For pcb design a electronic calliper metric and imperial is absolutely vital.
Its also handy for conversion between them.
Measure using metric then press mm/inch button and it converts.
PCBCAD51 download or CDROM 2019 version out now https://www.murtonpikesystems.co.uk
Old 18th July 2019, 04:52 PM   #74
RJM1 is offline RJM1  United States
I might be wrong, but I always thought that imperial rulers graduated in 10ths were machinist rulers.
As in take a tenth of an inch off here, Or we milled your cylinder head 5 thousandths..
Convert mm to inches - easy to remember!!Hide this!Advertise here!
Is 8 inches enough? nanl2053 Car Audio 3 29th June 2010 01:07 AM
Auto-bias - easy to convert to or not? GlidingDutchman Tubes / Valves 25 23rd July 2008 07:48 AM
How easy is it to convert from 110V AC to 240V AC? spikeyfaz Analog Line Level 19 26th December 2007 07:14 PM
Six inches... Godzilla Full Range 0 31st October 2006 05:57 PM
Copyright ©1999-2019 diyAudio
