Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
TCP/IP headache
TCP/IP headache
Old 5th June 2019, 01:10 AM   #11
vdi_nenna is offline vdi_nenna  United States
vdi_nenna's Avatar
TCP/IP headache
You need to get rid of the auto config ip address that starts with 169.x.x.x.
Check these tips out:
To enter the registry, open a command prompt and type regedit or enter regedit in Run:.
Don't change to many things at once in the registry and back it up, if you can before making changes.
Backup and Restore the Registry – Guide for Windows XP, 7, 8, 8.1, 10
Disabling Automatic IP Addressing (APIPA) | ITGeared.com
Windows 2000 / XP Disabling Auto IP-address generation
How to disable IP autoconfiguration in Core server - DHCP/IPAM - Spiceworks
YouTube
I build, therefore I am.
Old 5th June 2019, 02:34 PM   #12
Elvee is offline Elvee  Belgium
Elvee's Avatar
Problem solved: I have re-installed a different version of the drivers, and it worked immediately.
Probably an obscure compatibilty issue between the drivers and some component of the PC
. .Circlophone your life !!!! . . ♫♪ My little cheap Circlophoneİ ♫♪
Electrify your daily life!!! ....⚡⚡ ELEKTRIA ⚡⚡
Old 8th June 2019, 02:00 PM   #13
N101N is offline N101N
vdi_nenna,
thanks for the links.
Under HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\Tcpip\Parameters I have three Interface subkeys, only one is fully configured. Can I remove the other two?
So Automatic Private IP Addressing is unnecessary?
Old 16th July 2019, 05:07 AM   #14
Forman313 is offline Forman313  Norway
Forman313's Avatar
Stone age WiFi NICs and drivers on a modern router configured for speed is very hit and miss.
Nice job getting it connected.
Using WPA or did you get WPA2 working?
WPA isnt very secure, but as long as you dont have lots of sensitive and critical information on your network or the kid next door is a script kiddie ... who cares.
Im guessing your initial problem was caused by old drivers with no WPA2 support or awareness. It accepts the encryption key and thinks its connected. But its just a bug. There is no support for WPA2 in WindowsXP by default. A patch exists, but its not a part of any service pack or automatic update.
How did your laptop die?
Tweak or die!
Old 16th July 2019, 03:00 PM   #15
Elvee's Avatar
WPA2 works. It has the last service pack, and I did all the available updates
It was bent, apparently causing a solder spike on the main board to pierce an insulation sheet
TCP/IP headacheHide this!Advertise here!
SSE 100Hz Hum headache cowneko Tubelab 45 20th May 2015 01:44 PM
sv572 transformer headache vitalstates Tubes / Valves 30 1st April 2014 01:09 AM
Class D amplifier headache riko4628 Class D 12 10th January 2014 02:35 AM
Dynaco Stereo 400 Headache iaxxaxxai Solid State 39 31st May 2013 12:58 AM
Soft start headache Buzzy Solid State 34 27th December 2009 02:20 PM
Copyright ©1999-2019 diyAudio
