Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
18650 battery pack diagnosis.
18650 battery pack diagnosis. Please consider donating to help us continue to serve you.
Closed Thread
Old 2nd June 2019, 04:15 AM   #1
redrooster is offline redrooster  Australia
redrooster's Avatar
Default 18650 battery pack diagnosis.
I have a 7.40v, 18650 x 2 battery pack from an RC helicopter that has been laying around for a few years it reads 7.46v but only 0.03ma? Is there any hope of fixing this or is it a bin job? Whats the diagnosis Doc, is my little friend dead?
Old 2nd June 2019, 04:42 AM   #2
thaumaturge is offline thaumaturge  United States
thaumaturge's Avatar
Depends... sitting that long you may have to "prime it". No joke, this works if anything does. Need to get access to individual cells. Can probably just stick dressmakers pin through shrink wrapping to access center point. Then take a fully charged 18650 and hook it paralell to each cell for about 10 seconds. Each! Positive to positive, negative to negative. Do not hook up backwards! Do not leave hooked together for longer. Put on charger after priming. Then check it again. Report your results.
Doc (Thus I assumed you were asking me...).
Now teaching old dogma to new hicks!
Old 2nd June 2019, 08:48 AM   #3
redrooster's Avatar
What do you mean by center point? Is that the positive and negative of the batteries?
Old 2nd June 2019, 09:42 AM   #4
7,2v = 3.6 x 2 in series. That means cells are connected together in middle, the positive of one cell connected to negative of other. 7.2 volts will actually be a minimum voltage. Full chare on each cell is 4.3 volts making possible max voltage of 8.6 volts. So to prime cell that has negative connected to output wire, you must connect a positive lead where two celks are connected together. Like so
Minus wire of pack--------| |++++X--------| |++++++ plus wire of pack The X in middle is center point.
Doc
Old 2nd June 2019, 01:27 PM   #5
Refugee1 is offline Refugee1  United Kingdom
Refugee1's Avatar
I had a flat pack single cell camera battery that went like that.
I set my bench power supply to about 4.5 volts and turned the current limit down to about 100ma and dabbed it on for a couple of seconds.
It then triggered the charger and took a full charge.
Good battery chargers test the battery before starting to charge it.
Old 2nd June 2019, 05:26 PM   #6
redrooster's Avatar
This battery has a 3 wire input, red, black and white. The output is 2 wires red and black. So I take it I will zap it through the input red and black wires to be sure?
Old 2nd June 2019, 05:42 PM   #7
Refugee1's Avatar
Some cells even single ones have a FET inside them that shuts the output off if they become discharged that can also cut off the charging voltage at the end of charging like an electronic cigarette.
Old 2nd June 2019, 05:51 PM   #8
redrooster's Avatar
I've got it charging now, I zapped it through the inputs with a 9v battery for about 2 seconds then tried it in the charger and the red light flickered (it didn't do that before?) so I checked to see if it was charging with a DMM and it is charging at 8.46v. Thanks for the info fellas it saved this battery from a landfill.
Old 2nd June 2019, 06:43 PM   #9
sq225917 is offline sq225917  United Kingdom
Send a message via MSN to sq225917 18650 battery pack diagnosis.
Same works for gopro batteries they're notorious for over discharging
Old 5th October 2019, 05:24 PM   #10
redrooster's Avatar
Now I've got a vape that consists of 2 x 18650 batteries, it won't charge but I can't figure out how to kick start it? The anode is pushed down to make the connection when the top is screwed onto the batteries. I've pushed down with the positive probe of my Multimeter and grounded the black probe to the edge of the hole with no results? Any ideas on how would I get around this one?
Closed Thread
18650 battery pack diagnosis.Hide this!Advertise here!
Recharging circuit for 18650 battery Dibya Power Supplies 6 15th August 2018 09:21 AM
18650 battery management modules happysteve Power Supplies 4 19th December 2016 10:34 AM
18650 battery pack Camerong Power Supplies 26 19th April 2016 04:17 AM
Battery Charger for 15V Li-ION Battery Pack ??? Jan Dupont Parts 2 11th April 2009 03:18 PM
18650 battery holder? MikeHunt79 Parts 1 4th February 2009 01:30 PM
Copyright ©1999-2019 diyAudio
