Ok so this should be an ongoing project that may take all summer but I don't really know.
I want to build a boombox to kill all the 1200Watt Super BASS ULTIMATE! boomboxes out there. I am thinking of using the elf's as speakers or some 2-way joby, and I think the gainclone amp would do well. The main diffucultly will be the tuner and the cd player. Currently I think that it would be hard to run this whole system off batteries and still be able to cary it around, Unless I use cordless drill batteries maybe. So for now it can be AC powered. Mostly it will be integration and chassis design so I would love to hear suggestions from people to start me off, specifically in the CD tuner category. Thanks for the help.
Milo
PS I dont plan to make the cdplayer or the tuner but rather mod them from other things, like a computer cdplayer or something.
Milo
You could look at the old NEC SCSI CD-ROM drives. Most of the external SCSI ones have a display and control buttons, but require a caddy to load the disc. I saw a site where someone had modded a caddy based drive to be a "top loader". Most people who use these in audio are using them as a transport with an outboard DAC. There are audio and TTL digital outs on the back of the drive.
I think the model numbers are the CDR-601/602 for the external 4x/6x speed drives. There's also a top loader, the Multispin 3XP (CDR-400) that may be of use.
Figure on providing the drive with +12V @ 1amp and +5 @ 1amp .. Though I haven't measured what mine draw, that's what the switching power supply on the enclosed external version provides.
They're pretty cheap on Ebay ($10ish + shipping), or if you have a computer recycling/used computer store in your area, you might be able to find one there.
I'd of thought the obvious choice would be a car head unit.
Should run off a 14V source (13.8) perhaps a touch more.
If its a 4 channel unit with bridged outputs should manage
~ 25W per channel into 4 ohms and theorectically 50W per
channel into 2 ohms if the the unit can handle the current.
Speaker design is presumably is about compact efficiency.
I'd suggest a combination of a small sixth or 4th order
bandpass and a sealed high efficiency unit for mid treble,
with possibly a extra tweeter driver for treble fill, like the
one found here :
http://www.speakercity.com/clearance/clearance_drivers.shtml
sreten.
one found here :
sreten.
If you deliberately tune a box too high you will end up with less LF extension but increased SPL for a narrow frequency range. That's one of the tricks some of the boomboxes use. I have two prototype boxes with Dynaudio 17W75LQ drivers. The tubes used for the ports can easily be removed. If this is done then there is a remarkable increase in bass-SPL at the cost of precision. Just play around with a box-simulation tool a little and you will see what I mean.
You should of course only do this if you want to have "boom". You should also use a highpass filter in this case.
If you want to go for quality you better leave it of course.
Charles
Charles
This is a good project!
My Sony head does not require much current at all....there is a 10A fuse in the panel for it and it has NEVER blown, no matter how hard I push it (but it sounds crappy anyway at high volume when it starts to clip), I have 6-ohm speakers in the doors, so power RMS could not be more than 20W or so per channel. You will definatly need to use lower-impedance speakers to get any power out of them because of their small rail voltages.
-Matt
-Matt
A3rd.Zero said:I was thinking about a car head unit. Do you know what is typical current draw from a car head unit?
Phase_accurate: What?, Please explain.
Thank you
Milo
Hi Milo,
I'd expect static current to be quite low < 1 amp.
With typical efficiencies of class aB output stages and output
25W per channel clipping (x4) you can expect around 5 amps
average current drain, peak current ~ 10 amps.
sreten.
I would assume that using lower impeadence speakers would cause more current draw than the 6 ohm speakers you're currently using.
My personal opinion is that if you're looking to make a "hi-fi" boombox, I would probably stay away from the integrated amps in a car stereo headunit. However, it would probably be a great idea for the cd/radio portion of the boom box. Heck, you could even look for one of the double-din units that has a tape deck so you could really get that boombox effect
Maybe a decent headunit off of ebay + gainclones would equal something pretty dang tasty. Another option on the speakers is you could always have a foam bung or something to stuff the port to give you the "boom", with the option of removing it when you actually want it to sound decent
I like the idea of using the preouts and then using a gainclone or some such. It would be nice to use a head unit, which has the option of upgrading. I could even use one from the car and just plug it in when Im ready to go!
Ok now about the speakers, Im thinking something simple like the GR AV-1. I also like the idea of using a bg neo8 just for fun, but I dont know if I need a tweeter (not sure about its top end). Then the speaker boxes will in essence just be a woofer box, that might help get the low end.
Thanks for your help guys.
With ~2amps draw I guess i'm not going to try this with batteries, just AC on this one.
Milo
Milo
This year Panasonic makes an in-dash head unit using the new Texas Instruments digital amplifier technology. Described in detail here http://www.analogzone.com/avp_0105.htm. It is really efficient and provides 60 watts per channel of actual good clean RMS power. MXE CQ-C9800U.
- General Interest
- Everything Else
- The boombox project
