Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Cross-over technology and not talking passive or active:-)
Old 31st March 2019, 04:39 PM   #1
troystg is offline troystg  United States
troystg's Avatar
Default Cross-over technology and not talking passive or active:-)
Hi all,
I need some expertise on transistors and I think this is the place to find it.
I bought a motorcycle with all LED lights and want to pull a trailer with LED lights. Very simple to do with the circuit below.
However I can't help but think it would be better with transistors instead of relays.
What are you opinions and couldn't I just do this with a few transistors mounted on an aluminum plate dead bug style with a single small pcb on top?
Any help or positive criticism would be appreciated,
Troy
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 31st March 2019, 04:54 PM   #2
rayma is offline rayma  United States
I would use all standard automotive parts (like the relays), since they are intended
for rugged vibration and temperature, and will have fewer parts and connections
to go bad.
Old 31st March 2019, 05:04 PM   #3
MAAC0 is offline MAAC0  Portugal
Perhaps mosfets instead of transistors. There are automotive parts.
The problem are the shorts, since semiconductors burn easily.
You could also try solid state relays, I think they are short-circuit protected.
Old 31st March 2019, 05:26 PM   #4
troystg's Avatar
Of course everything will be fused properly.
But is there no transistor or mosfet that can be used to drive a few LEDs instead of slow, bulky relays?
Troy
Old 31st March 2019, 08:34 PM   #5
PRR is offline PRR  United States
PRR's Avatar
....think it would be better with transistors instead of relays.....
Why? My Honda cars, 2002 and 1996, are FULL of these relays. One chatters bad to tell me my O2 sensor is dying. I know the '02 has never had a relay failure, and I doubt the '96 has. Total of like 10,000 hours between them, which is a LOT for a motorcycle. Relays are Proven Technology.
OTOH... are there ANY specs on the parts you propose??
The relay may be 2W-4W. AFAICT nobody says what an LED taillight is worth in power because it is so tiny compared to an 1157 incandescent. My guesses run 3W-5W. It is not much more load on the brake/turn switches to wire the LED direct than to relay it with a conventional 30A car relay.
Unless the bike has had a major wires-up redesign in the last decade, the switches are probably good for 30 Watts of incandescents and will not be strained by a double-set of 5W LEDs. (However if I am wrong, I'm sure the replacement switch will be hard to get and costly....)
Old 31st March 2019, 09:25 PM   #6
Itsmee is offline Itsmee  England
Itsmee's Avatar
Is 5A enough?
2905491 Phoenix Contact | Mouser United Kingdom
Old 31st March 2019, 09:43 PM   #7
troystg's Avatar
Originally Posted by Itsmee View Post
$184 each? Ouch.
I will make a pcb similar to this, but I still think it can be done simpler with silicon.
https://www.amazon.com/gp/aw/d/B077V...G8TSLEZQ&psc=1
Troy
Old 31st March 2019, 09:48 PM   #8
PRR's Avatar
Conventional tail-lights return current through the shell and the vehicle bodywork. This needs a "high side" switch. For negative-ground systems without a boosted voltage we need a P-type transistor. P-types often cost more for their spec, but negligible in context of a motorcycle which can pull a trailer.
The simple single power device is an inverter. The application wants non-inverting. Another transistor is needed.
I modeled the LED module as a 48 Ohm resistor, 0.25A at 12V. For simulation I modeled the brake/turn switch source as a 0-12V source; even though "it is always zero or 12V" actually it must ramp, also we want to know if it may be marginal in extreme conditions.
Remember that a "12V" motor-thing supply may be 10V or 15V, and can have spikes to +/-100V. We need to survive the spikes and try to function when limping home on a dead dynamo.
Q26 M7 seems to work. The extra resistors hold things off when switch is disconnected, and resist spikes. Q26 is "any NPN", you can pull some from a dead VCR or Sansui. M7 should be P-MOSFET >5A >100V in a TO220, preferably insulated. It will run stone-cold unless something goes wrong; things go wrong so I'd use a generous part and bolt it to something, noting that the tab is "lamp hot" and can not touch motorcycle metal.
Input turn-on is 7V-8V for zero C to 50 C temperature, and nominal 12V system will always work it. (At 8V the LED is liable to be quitting, also modern bike ECU and other vital functions.)
Most LED tail-lights do NOT use the shell as return path, but are 2-wire floating. This opens the possibility of low-side switching. I do not like this! It is utterly non-standard and will befuddle many mechanics, even you when you stumble out late at night and find no lights. It also needs a constant-hot 12V wire in the harness, which is non-standard, and potentially dangerous. However this does save the extra transistor to invert logic. The MOSFET is now P-type, specs as for high-side. Turn-on is about 6.3V.
The Gate pins and any conductor hanging from it must be SHORT! Relay is modest gain to 200Hz, MOSFET is HIGH gain to GHz, and an inch of wire will induce oscillation. In dead-bug you can do very short.
Since we are where we are: these are *switching* MOSFETs, not some "AUDIO!" type you found in fancy amplifiers. While most audio MOSFET amps finesse switch-FETs into linear, there were a few real-linear FETs made. They switch, but not as good. And should cost a lot. These should be generic $1-$2 MOSFETs.
Old 31st March 2019, 10:07 PM   #9
troystg's Avatar
Please give me a minute ( or a few hours) to digest your post.
However this is not a "standard automotive electrical system ".
It was fully designed as an all LED low current system. It does not use the chassis as return it uses 2 wire for every circuit bit it is still 12v negative ground..
Honda CTX1300..
Troy
Old 22nd April 2019, 02:12 PM   #10
troystg's Avatar
Apparently there is already a solution for the part I was looking for. My FANTASTIC pcb guy already knew about it!
It's nice having friends smarter than me...
File Type: pdf _Infineon-BSP752R-DS-v01_02-EN-1144569.pdf (361.6 KB, 7 views)
Troy
Cross-over technology and not talking passive or active:-)Hide this!Advertise here!
Hi:) and a passive cross-over question BMWTurbo Car Audio 7 26th November 2011 12:00 PM
passive to active cross over conversion? owenhamburg Multi-Way 8 16th November 2009 01:41 AM
active cross over Kongen Multi-Way 15 23rd February 2005 03:26 PM
dB loss by using passive crossovers? Active vs Passive and 1st vs 4th order Hybrid fourdoor Multi-Way 3 11th July 2004 09:16 PM
Copyright ©1999-2019 diyAudio
