Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Can you tell original file from tube amp record? - test
View Poll Results: Which file is the original and which do you prefer
Apricot is the original file 7 46.67%
Avocado is the original file 5 33.33%
I prefer Apricot by listening 7 46.67%
I prefer Avocado by listening 7 46.67%
Multiple Choice Poll. Voters: 15. You may not vote on this poll
Old 21st November 2018, 06:11 AM   #11
PMA is offline PMA  Europe
PMA's Avatar
Thanks again for your kind words, George.
This is the test setup used for recording of the "tube amp file" that is compared to the original rip in this test. The amp is loaded by my regular speakers.
Pavel Macura http://pmacura.cz/audiopage.html
Old 21st November 2018, 06:34 AM   #12
indra1 is online now indra1  Indonesia
I would like to participate once my flu clears up. In the mean time, since the tube mu stage is inverting, could you clarify whether both files are of the same phase or one is inverted? If both files are of the same phase, could you describe where you put the second inverting stage. Thank you.
Old 21st November 2018, 06:58 AM   #13
PMA's Avatar
Hello indra1, thank you for your question. Both files have the same phase (and are time aligned, except for small time shift in microseconds in the amp channel). A/D input is balanced, so I made the phase inversion for the amp recording just by swapping +IN and -IN wires at the input XLR connector.
Old 21st November 2018, 07:04 AM   #14
jan.didden is online now jan.didden  Europe
jan.didden's Avatar
Originally Posted by TNT View Post
Using ABX23 / Lacinato 2.37 on Mac and I could quite fast identify a preference while playing the version sighted. I prefer Apricot and I think that Avocade is the "tobes"
My very quick run ended like:
Completed trials: 15
Number correct: 8 (53.333336%)
Confidence that your results are better than chance: 0.5
Last played: A
Individual test results [choice/actual] from among 2 possible files:
Test #1 [ A / B ]
Test #2 [ A / B ]
Test #3 [ A / A ]
Test #4 [ B / A ]
Test #5 [ A / A ]
Test #6 [ A / B ]
Test #7 [ A / B ]
Test #8 [ A / B ]
Test #9 [ B / A ]
Test #10 [ B / B ]
Test #11 [ B / B ]
Test #12 [ A / A ]
Test #13 [ B / B ]
Test #14 [ B / B ]
Test #15 [ A / A ]
But I felt I got the hang of it better at the end and this seem to have been the case.
I belive in ABX. I think it will serve a result that could guide me. The difference between the files where not in my opinion great and I could live with both SQ in some sense but still, I didn't care for the soft/muddy base in Avocado.
TNT, are we understanding this the same way? 8 correct out of 15 is not better than chance, and would mean that you can't hear a difference.
Jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles SilentSwitcher now at diyaudio store SilentSwitcher. Treg high voltage regulator
Old 21st November 2018, 07:22 AM   #15
PMA's Avatar
This is my result in "brief" listening, just one test of one (no more trials). I will try again
Code:
foo_abx 2.0.2 report
foobar2000 v1.3.7
2018-11-21 09:14:55
File A: apricot.wav
SHA1: 366faaef08134ef83262c95ee8a5ccbdeedb7395
File B: avocado.wav
SHA1: b404fd5526030ace6f56bead6dd1f780cab0a533
Output:
WASAPI (event) : OUT (DUO-CAPTURE EX), 24-bit
Crossfading: NO
09:14:55 : Test started.
09:16:13 : 00/01
09:16:26 : 00/02
09:16:38 : 01/03
09:16:48 : 02/04
09:16:59 : 02/05
09:17:08 : 02/06
09:17:19 : 02/07
09:17:27 : 03/08
09:17:39 : 03/09
09:17:51 : 04/10
09:18:01 : 05/11
09:18:12 : 05/12
09:18:22 : 06/13
09:18:58 : 07/14
09:19:07 : 08/15
09:19:16 : 09/16
09:19:16 : Test finished.
Total: 9/16
Probability that you were guessing: 40.2%
 -- signature --
2221ad1a5108d55c51f22159f1a36313ab4808f2
So, same as TNT, my score was 8/15 before I hit 9/16
Old 21st November 2018, 07:30 AM   #16
gpapag is offline gpapag  Greece
gpapag's Avatar
Hi Indrawan
The content of the two files is of the same polarity (I've checked it)
George
["Second Law is a bitch." - SY]
["I insist on respecting the means of the average person working in their garage/basement." -Scott Wurcer]
Old 21st November 2018, 08:12 AM   #17
OK, got it, thanks.
Old 21st November 2018, 08:24 AM   #18
TNT is offline TNT  Sweden
Jan
Thats how it turned out - yes.
I think I could do better - maybe I will try. Apparently I just couldn't "wing it".. But I did want to succeed - who wouldn't like to claim "golden ear"
More distortion to the people!
Old 21st November 2018, 12:07 PM   #19
PMA's Avatar
I am getting better
Code:
foobar2000 v1.3.7
2018-11-21 14:00:10
File A: apricot.wav
File B: avocado.wav
Output:
Crossfading: NO
14:00:10 : Test started.
14:02:02 : 01/01
14:02:16 : 01/02
14:02:26 : 02/03
14:02:36 : 03/04
14:02:45 : 04/05
14:02:53 : 04/06
14:03:05 : 05/07
14:03:19 : 05/08
14:03:31 : 06/09
14:03:43 : 06/10
14:03:52 : 07/11
14:04:01 : 08/12
14:04:14 : 09/13
14:04:27 : 10/14
14:04:45 : 10/15
14:04:55 : 11/16
14:04:55 : Test finished.
Total: 11/16
Probability that you were guessing: 10.5%
 -- signature --
319534ee2037ab2caae98e66f0ed5721db5b9f10
Yes it is the bass sound that seems to make a difference.
Old 21st November 2018, 12:21 PM   #20
PMA's Avatar
I think it might be interesting to show what is this hybrid power amplifier bringing into the recording chain:
- frequency response, there is a -2dB decrease at 20kHz
- distortion vs. amplitude from 1mV to 5.5V (fits to rec level) at 1kHz is shown
- distortion vs. frequency is shown, which is pretty flat
- output impedance is 0.23 ohm, not very low but not very high
- SNR for the FS recording level is -90dB(A)
Can you tell original file from tube amp record? - testHide this!Advertise here!
What CD or Music file YOU USE to test bass??? murillollirum Music 48 26th November 2018 08:25 PM
How to record/save a streaming website lesson as an MP3 file? Markg2 Software Tools 11 21st October 2016 07:01 PM
How can we interface the PCM4202 with a SD card to record wav file on a SD card ? gaetan8888 Digital Line Level 3 11th June 2013 02:05 PM
Test record? Etocynned Music 2 20th March 2012 12:01 PM
Another file upload test weinstro Forum Problems 5 24th September 2007 08:47 PM
Copyright ©1999-2019 diyAudio
