Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Negative feedback - right or wrong to use?
Old 24th February 2018, 04:19 AM   #91
globalplayer is offline globalplayer  Germany
globalplayer's Avatar
LOL!
OK.
Old 24th February 2018, 05:43 AM   #92
AllenB is offline AllenB  Australia
My best wishes to Frau Global
Old 24th February 2018, 09:05 AM   #93
Mikelandjelo is offline Mikelandjelo  Serbia
Originally Posted by elukacs View Post
Hi Nigel,
check TAS5614A power stage data sheet. Due to the internal compensation it has
80 dB PSSR.
Furthermore it is a BTL design which lowers supply rail pumping.
PS: datasheet http://www.ti.com/lit/ds/symlink/tas5614a.pdf
Old 24th February 2018, 09:20 AM   #94
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Originally Posted by Davey View Post
So God selected you for this revelatory improvement to amplifier design, but told you not to say anything about it?
I guess God is laughing at all of us poor souls...through you?
What a pathetic thread.
Dave.
Ironically, He was big on negative feedback
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 24th February 2018, 02:30 PM   #95
MarcelvdG is offline MarcelvdG  Netherlands
Hi Nigel,
80 dB PSSR.
The functional block diagram depicts a feedback loop of unknown order for each of the four output stages.
Old 24th February 2018, 02:45 PM   #96
Fast Eddie D is offline Fast Eddie D  United States
From the data sheet.
The TAS5614A is a high performance digital input class D amplifier with integrated closed loop feedback technology.
The problem with lying to engineers about engineering topics is that we can read the datasheet. We're not gullible consumers of the products. We design the products!
Nice try though.
Old 24th February 2018, 03:20 PM   #97
elukacs is offline elukacs  Hungary
Yes, I wrote this part has some unknown local feedback inside.
But who cares if the result is good, the PWM generation process is out of this feedback,
and on the design level you don't have to deal with analog problems from the speaker
port to the input of pwm gen. You can see it as fb less solution with good enough driver stage.
Old 24th February 2018, 03:28 PM   #98
In the context of this thread, I expect everyone cares about it (except you, apparently). I'm really curious why TI chose such a weird solution, with open-loop PWM generation followed by an N-th order analogue feedback loop.
Old 24th February 2018, 04:05 PM   #99
TI: Earlier they made open loop driver stages only. Then probably they realized that
with some compensation they can improve on timing of FETs and PSSR.
I would be surprised if that is a complex Nth order loop.
I think the point here is that they splitted the problem into PWM generation in digital domain, and making good enough driver stage. The former is limited only by the DSP and its clock source.
The later can be improved as FET technology improves.
Old 24th February 2018, 07:42 PM   #100
LOL.
Negative feedback - right or wrong to use?Hide this!Advertise here!
'Wrong' MOSFET structures for power followers - what negative characteristics? multi-volti Solid State 5 18th November 2017 02:53 PM
Electrolytic Capacitor - wrong polarity Marking for the negative Pol outsidee tiefbassuebertr Parts 2 15th October 2017 01:54 PM
Negative Feedback Amplifier with embedded Positive Feedback Booster Koonw Tubes / Valves 57 24th June 2015 08:05 PM
How the negative feedback really works and an alternative feedback question Amit_112dB Solid State 37 21st April 2014 03:16 PM
Better Audio with or without NFB (Negative Feedback) - for me the wrong Question tiefbassuebertr Solid State 61 31st December 2012 05:36 PM
