Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Low Level Detail: An experimental search and test.
Old 16th September 2018, 05:13 PM   #71
Pano is online now Pano  United States
Pano's Avatar
Yes. See earlier in this thread.
Take the Speaker Voltage Test!
Old 16th September 2018, 05:33 PM   #72
DonVK is offline DonVK  Canada
DonVK's Avatar
A very interesting topic.
I have noticed a fading detail effect. When a single driver gets increased lower frequency power (and movement) it appears to diminish the detail of the higher + lower amplitude frequencies. It looks like superposition problem. I was never sure if it was me or the driver.
Would the level of detail the driver is capable of be indicated by it's HD (THD or even harmonics ) ?
Old 16th September 2018, 08:57 PM   #73
chris661 is offline chris661  United Kingdom
chris661's Avatar
Originally Posted by Pano View Post
The main stumbles I found were getting the files lined up at the correct staring point and also getting them level matched.
Hey Pano,
A lot of that can be sorted within the desk - move the recording slider back to the start, press "track" on the pink noise and "record" on the mic input, and I'll be able to subject the speaker to the same section(s) of pink noise as many times as I like, with other things mixed in as needed.
In theory, that'd get everything to work perfectly.
In practice, I expect the increased noise levels present in the difference file to swamp any changes in the distortion from driving the speaker with other signals.
We'll see.
I suppose this'd be a good way to test amplifiers, too.
Chris
Old 16th September 2018, 09:27 PM   #74
Pano's Avatar
It certainly would be easier with power amps and line level circuits. I had pretty good success with line level signals.
You could compare two circuits to find if one "preserves" low level detail better than another.
Low Level Detail: An experimental search and test.Hide this!Advertise here!
Level-dependend Sound Quality by certainly Bass Drivers - very bad sound at low level tiefbassuebertr Subwoofers 11 3rd March 2012 10:54 AM
Power/efficiency/enclosure - Quality and Detail at low volumes? JammyBStard Multi-Way 7 19th December 2011 08:47 PM
Low power amplifier P8W4R- detail clear sound mac1257 Solid State 5 28th October 2011 06:20 AM
Level-dependend Sound Quality by certainly Bass Drivers - very bad sound at low level tiefbassuebertr Multi-Way 1 2nd April 2010 04:12 AM
Regulation, GC and low-level detail Dr.H Chip Amps 17 5th August 2004 03:58 AM
