Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Digitalized music causing stress??
Old 30th April 2019, 01:56 PM   #211
dreamth is online now dreamth  Romania
All we need now is to get into high end BS cables ...
Most "highend-ish " cables are just coax cables adding capacitance to the output of the amplifiers where you should simply use thick separate wires and nothing more.Well...I'm not talking Sigma Drive or motional feedback here
The amplifiers with lower damping factors and high bandwidth usually get to oscillate and what we get as "airy sound" is actually high freq (sometimes even mid range ) intermodulation products in the upper audio range...It is well known that the highs content (be it harmonics, oscillations, noise) creates the impression of a much larger soundstage,
but, instead of listening to a neurosurgeon or a psychiatrist , we prefer to talk with audiophile guys as it makes us feel safer and healthier
A few months ago i found a guy on Facebook who agreed to change his most expensive cabling attached to some very expensive speakers with separate bass and mid high section sockets and i told him exactly this:
Go to the closest Chinese shop and buy the cheapest but thick enough(2.5mm thick) wires that can deliver the current to your speakers at 50 watts(i had a quick approximate calculus for that and 1.5mm would have been fine for the purpose of this trial, but all he could find was 2.5 mm copper wires for electricians) .
Then you get separate wires from the same amplifier output to each input (mid-high and bass) of the speaker.
A week later his response:
It sounds cleaner and tighter, much more precise, its just that i prefer the expensive cables because i live in a small room and i have the feeling of a more spacious sound...
Unfortunately he couldn't find aluminium 1.5 mm wires ))))
I'd suggest the "digitalized stressed persons" to get a walk in nature...It's much cheaper and healthier.
Old 30th April 2019, 02:09 PM   #212
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Originally Posted by scott wurcer View Post
It is not hard to map the gradient of a real music signal, I doubt much surprising would show up.
Well you could use worst-case max amplitude at 20kHz. Hence the rule of thumb of 0.15V/uS per V output amplitude. Plus the usual audio safety factor of 7 x gives, say, 1V/uS per output volt.
Jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 30th April 2019, 02:13 PM   #213
jan.didden's Avatar
And I still like the way Eric Margan said it:
Old 30th April 2019, 02:16 PM   #214
TNT is offline TNT  Sweden
Originally Posted by Alex Ra View Post
Sir, thank you for sharing your personal opinions with us, but personally I stopped understand your statements and their purposes long time ago, despite all my efforts to get them.
I think I understand the divide.
More distortion to the people!
Old 16th May 2019, 03:40 AM   #215
Tromperie is offline Tromperie  Australia
I think I do too. DF96 is an engineer who actually understands the subject, while Alex Ra is an "audiophile".
Source: Daphile on old PC from the tip * Storage NAS: FreeNAS 11 * Pre-amp: DIY PGA2310 * Amps: 8 x LM3886TF
Xover: 24dB @ 300 and 3,000Hz * Speakers: DIY design CNC cut 54 laminations * Drivers SB 10", SB 5", VIFA 1" VTG
Digitalized music causing stress??Hide this!Advertise here!
Stress testing a car SMPS? MikeHunt79 Power Supplies 14 29th February 2008 11:26 AM
What's causing that #$%&@$ humm?? sachi Chip Amps 10 9th February 2006 01:29 PM
rectification and xfmr stress beamnet Tubes / Valves 16 19th September 2005 03:51 PM
cap on speaker causing amp to cut out dvdwmth Chip Amps 1 12th September 2004 10:00 PM
Copyright ©1999-2019 diyAudio
