Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
speaker cable myths and facts
Closed Thread
Thread Tools
Old 7th April 2021, 10:10 PM   #1331
thetubeguy1954 is offline thetubeguy1954  United States
thetubeguy1954's Avatar
Send a message via Yahoo to thetubeguy1954
Originally Posted by Evenharmonics View Post
So you haven't done it. OK.
Ah, the classic smear job.
Late Peter Aczel pointed this out decades ago.
The Ten Biggest Lies in Audio - ecoustics.com
Even,
1) I actually have done it and that's the only I will or would do it again.
2) Why's the truth a classic smear job? Because it disagrees with your beliefs?
3) The #1 BIGGEST lie ever told about Audio was "The Ten Biggest Lies in Audio."
Thetubeguy1954
Central Florida Audio Society--SETriodes Group--Space Coast Audio Society--Full-range/Wide-range Drivers--High Sensitivity Speakers--Front & Back-Loaded Horns.
Old 7th April 2021, 10:42 PM   #1332
kn0ppers is offline kn0ppers  Germany
I am sure you have. And I am sure the more expensive the cable was, the better it sounded. And when the most expensive cable was plugged in, your wife even came over from the other room asking what you just changed because it suddenly sounded so much better than before
Old 7th April 2021, 11:24 PM   #1333
kn0ppers, I have indeed done DBTs as I suggested with the exception of there being no CCTV installed. Instead, a person sat about 10 ft behind me to make sure I didn't peak at what wires were installed.
You might be surprised to hear a subjectivist such as me admit that it wasn't always the higher-priced wire that sounded best. That said, I'll readily admit many times it was! The reality is the closer the wires were in price the less often the more expensive wire would sound best.
Two power cords I own that would be a perfect example of this are the $1545 Snake River Audio Cottonmouth Signature and the $1250 Sablon Audio Gran Corona. They sound very similar sonically, but the Sablon while being $300 less expensive takes everything the Snake River Audio power cord does just a couple of notches higher and is the power cord I preferred. I still use both power cords in my system today and highly recommend using either.
And no for your information my wife never noticed from another room when I changed wires. She did however do that when I changed audio components a couple of times!
Thetubeguy1954
Old 8th April 2021, 04:20 AM   #1334
Evenharmonics is offline Evenharmonics  United States
thetubeguy1954, do you have any involvement with electronic audio products or sales of those? I'm asking because you've checked the boxes of those who shill for such products, "anyone who cannot hear the difference between a cheap $100 pr of ICs and a high-quality (not high-priced) pair of ICs has to either be tone-deaf or listening on an audio system that's not very musically resolving", "person is being tested puts a strain on them while they're listening", "but the reality is it's not a valid DBT". Classic shill lines overused for years, even on this forum.
Old 9th April 2021, 01:43 AM   #1335
Joel Wesseling is offline Joel Wesseling  Canada
Joel Wesseling's Avatar
Wow, with those names, each one will sound amazing for a time, but after I stop hyper-focusing on positive aspects of the sound in front of me, then swapping them for lamp cord, I would hear no difference between them.
Old 9th April 2021, 02:22 AM   #1336
TonyTecson is offline TonyTecson  Philippines
diyAudio Moderator Emeritus
TonyTecson's Avatar
Originally Posted by stvnharr View Post
Then there is the issue of connecting the shield to just the "source" end and making the shield a stub, or connecting the shield to both ends. BJ makes a good case for connecting at both ends. And that's how I do it when I make a shielded IC.
There are certainly a lot of opinions about the perceived value of the shield as a stub. But there's not much empirical supporting evidence, just opinion.
Then again, how much of an issue is RFI in a short IC cable? Unless one happens to have a amateur radio hobbyist next door who is transmitting when you are listening, or if you live under, or near to, a mobile phone tower...how much of an issue is this?
Oh, I know, it's supposedly everywhere all the time.
i worked as a QC/QA engineer in Oil and Gas refinery construction projects, and as a matter of good practice, cable shields are terminated to ground only at one location and as to which end it is specified by construction specs at the very beginning....maybe this is where the audiophile crowd got this practice...
i have nothing against this really....recently i have been using twisted wires more than shielded types....
Old 9th April 2021, 03:55 AM   #1337
PRR is offline PRR  United States
PRR's Avatar
Originally Posted by TonyTecson View Post
i worked as a QC/QA engineer in Oil and Gas .... ..... which end it is specified by construction specs at the very beginning ....maybe this is where the audiophile crowd got this practice.......
I think in most analog signal wiring, the Telephone Company was there first. While most telco cable is not shielded, or used the now-rare overall lead sheath for weather resistance, the telco knew ALL kinds of cable.
Old 9th April 2021, 04:17 AM   #1338
TonyTecson's Avatar
lead sheeted 6.6kv power 35mm sq 3 phase cables, paper in oil insulated with steel wrap around and lead outers sheet are what we had to lay for temporary kiosk in our construction projects, i think i have seen a lot of cables in my time, as high as 110kv in single cores with 100mm diameter....
Old 9th April 2021, 04:57 AM   #1339
benb is offline benb  United States
Originally Posted by MITsound View Post
I have too much difficulty believing someone would design and build an amplifier that will not perform properly without using expensive connections between it and a pair of speakers.
Aside from everything else, it seems like a loser business model, purporting that the amplifier design is flawed, but will be fixed with some other company's wire.
No one would ever say a high-dollar amplifier is flawed, only that it is "incompatible" with some models of cables and speakers. The dealer knows from experience what works with what, so just let the dealer choose for you ...
Besides, making an amplifier that works driving all cables and speakers would cost extra money that would be better spent on marketing.
Old 9th April 2021, 09:15 AM   #1340
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
Don't kid yourself. Naim and NVA in the UK both build / built amplifiers sans output Zobels that more or less mandate the use of low capacitance speaker wire to ensure stability. In the latter's case, they even stress that if you don't use their wire, you will invalidate the equipment's warranty, and users requiring warranty work may even be obliged to provide proof of wire purchase before they will consider whether they are under any obligation to provide such work. As I recall, Naim have softened up their approach in this regard over the last decade or so, although I don't keep close tabs on such things.
www.wodendesign.com (commercial site)
www.frugal-horn.com www.frugal-phile.com (community sites)
Closed Thread
speaker cable myths and factsHide this!Advertise here!
Thread Tools
myths and facts on electrolytic capacitors in audio circuits krachkiste Solid State 92 8th July 2012 01:10 PM
25 pair cat 5 cable for speaker cable? mpmarino Parts 19 3rd March 2006 04:46 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
