Equipment & Tools From test equipment to hand tools
What's on your workbench ????
Thread Tools
Old 31st October 2020, 04:59 PM   #661
mbrennwa is offline mbrennwa  Switzerland
mbrennwa's Avatar
suzyj, what's up with that phone? Love it! Those things don't work anymore where I live.
Old 31st October 2020, 10:05 PM   #662
suzyj is offline suzyj  Australia
suzyj's Avatar
It still works for receiving calls, but I need a DTMF dialler to make calls.
I’ve been meaning to get a pulse to DTMF converter for ages.
http://www.suzyj.net
Old 31st October 2020, 10:27 PM   #663
rsavas is offline rsavas  Canada
I still have a pulse line, so my old rotary dialer still works. Bell wants $3.25/month for tone service, I can do without :-) I have all the Bell phone features too, just have to switch the phone to tone and away you go ...
I recall using some old Motorola CMOS parts to make some phones and ringers
MC145740, TP5089
Old 8th November 2020, 09:10 AM   #664
suzyj's Avatar
My 3585B is on the bench, for my annual game of “Find the popped tantalum”.
It was hiding underneath, on the input board:
Old 16th July 2021, 03:23 PM   #665
jackinnj is offline jackinnj  United States
jackinnj's Avatar
@Demian -- you might be amused watching this Youtube by "Marco Reps" on fixing up a Fluke 732A which went out of spec: Fluke 732A DC Voltage Standard & low cost DIY attempt - YouTube
"All models are wrong, but some are useful" G. Hill
Old 16th July 2021, 06:00 PM   #666
1audio is offline 1audio  United States
The 732A is a pain to work inside the "oven". What I thought was a failure seemed to be a bad connection to a thermistor. Getting all the stuff back in with the foam insulator in place -not fun.
I'm really reluctant to change any parts that have not failed simply because it starts from an unknown state then. All the metrology stuff depends on long term predictability. The 732A seems to have the best track record, better than the newer 732B. Once you change something you open up the potential for problems. Still I would like to swap for a better battery/charger solution but it would need to be proven.
This reminds me that I need a fresh cal check on it soon.
Also on my bench now- The Optimation AC110 calibrator for calibration (a long story) 2 Fluke 932A AC meters, Boonton 9200A power meter HP 8116a function generator. Shortly- fix a funky oscillator in a Boonton 1120. No bench space left.
Demian Martin
Product Design Services
Old 22nd July 2021, 04:36 AM   #667
BKnut is offline BKnut  Australia
BKnut's Avatar
I worked aside the standards calibration lab, their Fluke 732A was playing up with the weekly measurement data. After some close observation of the following weeks with the assistant to the Electronic Meteorologist, if was found that the assistant regularly had fish and chips on Fridays at the company's local canteen. The oils on his fingers contaminated the banana jacks and the measurement leads that would cause electrical leakage. I don't think Sherlock would have solved the mystery, it was funny but a serious matter. The assistant was told to wash his hands after lunch, particularly on Fridays
1 Pascal=94dB
Old 22nd July 2021, 04:40 AM   #668
BKnut's Avatar
I found it, thanks for the photo
1 Pascal=94dB
Old 22nd July 2021, 05:17 AM   #669
BKnut's Avatar
Originally Posted by simon7000 View Post
Then forothe stuff I use notebooks with pages covered in conductive foam.
Brilliant idea there Simon, the IC folder would be very compact and easy to find.
1 Pascal=94dB
Old 22nd July 2021, 08:56 AM   #670
anatech is online now anatech  Canada
anatech's Avatar
Hi suzyj,
Yep, pretty easy to find those. But, there are so many just everywhere throughout!
Luckily I don't seem to go through failures like you might. My lab remains at about 20 °C, so that might be one reason.
-Chris
"Just because you can, doesn't mean you should" © my Wife
  Reply to this post
What's on your workbench ????Hide this!Advertise here!
Thread Tools
Heavy Duty Workbench for Milling Machine Vikash Equipment & Tools 17 7th July 2009 12:23 PM
Workbench safety practices? Stormrider Equipment & Tools 3 3rd August 2008 05:08 PM
Help Setting up an electronic workbench JMB Parts 6 8th December 2007 04:32 PM
Electronics workbench = garbage sndscietist The Lounge 1 3rd July 2005 07:56 PM
Electronics Workbench 4 opamp sim bug. Circlotron Everything Else 0 12th April 2004 12:47 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
