Equipment & Tools From test equipment to hand tools
What are the advantages of a bench top multimeter?
Thread Tools
Old 26th October 2021, 02:45 AM   #41
trobbins is offline trobbins  Australia
trobbins's Avatar
OP, what meters do you have now?
I'm a fan of clipping on many meters, compared to just using 1 or 2 meters and having to move probes around in energised equipment.
As such, I'd suggest aiming for at least 2-3 small battery operated DMM's with limited capabilities (eg. cheap 4 digit handhelds like Aneng 8009) plus one bench meter. If you do a cross comparison of typically used voltage and current measurements each 6-12 months then you have confidence that none of your meters is loosing accuracy. The one bench meter provides all the additional functions that the smaller meters don't.
If you are in to audio then I'd recommend looking closely at the low and high bandwidth frequencies of any meter you are contemplating. If you are doing valve stuff, then perhaps look at the input resistance of the DC and AC voltage ranges, as some meters provide > 10Meg. If you may want to log some measurements then older equipment with GPIB style comms requires at least $150 extra spend for an interface adaptor, whereas USB connection to the meter will depend on what software is available for that meter.
If you get in to wanting confirmed accuracy and with > 4 digits, then purchasing a new bench meter in the future still fits in with that group of meters.
Old 26th October 2021, 02:49 AM   #42
SoaDMTGguy is offline SoaDMTGguy  United States
Learn, try, fail, learn
SoaDMTGguy's Avatar
Right now I have a Klein MM400, and two super cheapo Harbor Freight meters to do just as you said with multiple test points. My primary use will be audio. I might dabble with valve stuff, but not as my primary work.
Old 26th October 2021, 07:57 PM   #43
johan is offline johan
This is a nice 4-wire milliohm meter that I also built (with some modifications to Barbouri's/Greg's design): Milliohm Meter Version 1.5 - Barbouri's Electronics Projects
This design is originally based on Scullcom's videos on youtube Scullcom – Hobby Electonics
  Reply to this post
What are the advantages of a bench top multimeter?Hide this!Advertise here!
Thread Tools
Bench Multimeter - Which one to get ? Fluke Agilent ? HP8903B Equipment & Tools 15 8th December 2012 08:57 PM
bench top wave soldering robmil Equipment & Tools 2 3rd October 2011 10:53 AM
Bench Multimeter for Mic Preamp design Ronnie4416 Equipment & Tools 16 4th April 2011 01:44 PM
HV SS bench top power supply, advice needed panos29 Tubes / Valves 11 19th December 2006 08:06 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
