Equipment & Tools From test equipment to hand tools
What are the advantages of a bench top multimeter?
Thread Tools
Old 23rd October 2021, 12:43 AM   #31
rayma is offline rayma  United States
It'll keep you warm, too.
Old 23rd October 2021, 02:17 AM   #32
1audio is offline 1audio  United States
For $72 this is a great value: High-Precision Resistance Tester Milliohm Meter Accurate With OLED USB Charging | eBay You should get a good reference to verify its accuracy. It reads out to 5 digits which is close to as good as you can get at those low values.
Demian Martin
Product Design Services
Old 23rd October 2021, 02:27 PM   #33
jbau is offline jbau  United States
jbau's Avatar
Originally Posted by Andersonix View Post
Also Mark Johnson mentioned 4 wire. What is the cheapest way to measure low value resistances accurately? I sometimes want to closely match 0.1 Ohm resistors for Papa's amps....
Any decent LCR meter with 4-wire connections and short compensation will measure milliOhms just fine, and will be useful for other things too.
Old 23rd October 2021, 06:11 PM   #34
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Marco Reps video on the 30 year old HP3458. HP 3458A - Why is this 31 year old Multimeter UNRIVALLED? - YouTube
I was fortunate to get an HP3456A when the Dot-Com economy went bust, around $100. No such luck today. For every day use the Fluke 77 is used 60% of the time, and a set of Tektronix DM511's 40%
"All models are wrong, but some are useful" G. Hill
Old 23rd October 2021, 08:13 PM   #35
Andersonix is offline Andersonix  Sweden
Andersonix's Avatar
Is there such as thing for under $650?
Old 23rd October 2021, 08:18 PM   #36
The DER5000 has been the go to LCR meter for years: https://www.amazon.com/5000-Handheld...TESTING_DEVICE $130 at Amazon.
Demian Martin
Old 23rd October 2021, 09:30 PM   #37
Mark Johnson is offline Mark Johnson  United States
diyAudio Donor
Mark Johnson's Avatar
Demian, I've got a DE-5000 from DER-EE and I assure you it cannot make 4-terminal Kelvin measurements. All it has is DUT+, DUT-, and Guard.
On the other hand, I also own an ET4510 ($421 at AliExpress, $679 at Amazon) and that LCR meter DOES have four BNC jacks on the front panel for 4-terminal Kelvin measurements. They label the terminals (Hforce), (Hsense), (Lforce), (Lsense). The box includes the test leads with BNC and alligator clamp probes, along with the instrument and power cord.
_
Old 23rd October 2021, 09:56 PM   #38
I have no experience with the DER5000 myself. It is often recommended however. I use an ESI Videobridge which is overkill for most measurements.
Demian Martin
Old 24th October 2021, 04:16 PM   #39
jbau's Avatar
A longtime friend and customer (owner/mod of the Lecroy users group), who owns or had access to some high-end LCR/Z meters from GR and HP, bought one of these XJW-01 on a whim:
0.3% XJW01 Auto LCR Digital Bridge Resistance Capacitance Inductance ESR Meter | eBay
At that price I was skeptical. He took a selection of different LCR components and measured them on the XJW-01 and the high-end meters, and sent me the chart. I couldn't argue with the results, they were impressive. His quote:
"The thing to note on that spreadsheet is how close the meters track each other. I guess in reality we can thank Henry Parson Hall for that as they all use his measurement method in the designs."
As a bonus, the BNC's are spaced the same as test fixtures from HP, B+K, and others (22mm) so if you have any of them laying around you can use them with it. He also made up some pcb's which attach, with a fixture for measuring SMD parts, which I've encouraged him to offer for sale.
If I didn't already have several LCR meters on the bench I'd get one; at the price they're a no-brainer. Numerous vendors sell the XLW-01 with different accessories, so look around.
Old 24th October 2021, 04:34 PM   #40
NareshBrd is offline NareshBrd  India
DSO138 2.4 inch TFT Handheld Pocket-size Digital Oscilloscope Kit DIY Parts Electronic Learning Set Soldered buy online at Low Price in India - ElectronicsComp.com
$11 or so without cell.
See the specs before laughing.
What are the advantages of a bench top multimeter?Hide this!Advertise here!
Thread Tools
Bench Multimeter - Which one to get ? Fluke Agilent ? HP8903B Equipment & Tools 15 8th December 2012 08:57 PM
bench top wave soldering robmil Equipment & Tools 2 3rd October 2011 10:53 AM
Bench Multimeter for Mic Preamp design Ronnie4416 Equipment & Tools 16 4th April 2011 01:44 PM
HV SS bench top power supply, advice needed panos29 Tubes / Valves 11 19th December 2006 08:06 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 13.64%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
