Equipment & Tools From test equipment to hand tools
Boonton 1121 Audio Analyzer: some questions
Thread Tools
Old 14th September 2021, 08:16 PM   #21
krais23 is offline krais23
Originally Posted by 1audio View Post
I just checked one of mine for the same signals to get a baseline.
Conditions- loopback BNC to BNC, input and output floating, 1 KHz, level 14V 50 Ohms source (spl 75), TP 2 out output board clip lead to chassis. (do not connect before boot is complete).
Thanks so much Demian for all the effort and guidance. I'll try to replicate these baseline measurements and will report back.
A few new player's questions if you don't mind (you might be overestimating my skill level):
- You mean putting the 1121 in special function 75 when doing the measurements, correct?
- "TP5 ac coupled at high gain": do you mean setting the probe in 1:1 mode?
Old 15th September 2021, 12:02 AM   #22
1audio is offline 1audio  United States
Special 75 sets the output impedance to 50 Ohms. That reduces its sensitivity to external noises. TP5- AC coupled with high gain to see the noise. I did use 1:1 on the probe for more sensitivity. And 20 MHz band limit to lower the noise of the scope re: input. There isn't anything that's liable to oscillate at 100 MHz in a stock unit. The 5534's won't get there. Is there a radio station near you?
Demian Martin
Product Design Services
Old 15th September 2021, 07:42 PM   #23
Hmm... yes I do think there is a FM radio transmission tower within half a mile from my house but not 100% sure if it's still in use.
Old 19th September 2021, 06:39 PM   #24
Today I tried to reproduce the baseline measurements (loopback BNC to BNC, input and output floating, 1 KHz, level 14V 50 Ohms source (spl 75), TP 2 out output board clip lead to chassis). Distortion measured was around 0.0025%.
I didn't know how to get a scaled output of the input signal so measured TP1 on the source board instead.
First picture: source TP1 (yellow) vs. TP5 on source board (green) (AC coupled, 20MHz bandwidth).
Second picture: source TP1 (yellow) vs. Monitor out (green).
Old 19th September 2021, 06:51 PM   #25
Btw, I noticed some random glitches to the signal at TP5 (source), see video capture below.
Old 19th September 2021, 07:42 PM   #26
That all looks typical for a stock unit. The second harmonic is the dominant and can be addressed on both source and analyzer. I think its mostly from the analog multipliers.
You can see the sample pulse on TP5 but its mostly lost in all the RF noise you are getting.
I have noticed that there can be some noise across the grounds in these which is annoying. The balanced to balanced is an effort to reduce it. I get those random glitches as well. It may simply be random noise from something getting it.
I hope Tuesday I'll be able to post some simple upgrades as a first step. I'll be gone for a week after Tuesday so any more documentation will need to wait until I return.
Demian Martin
Old 20th September 2021, 05:52 PM   #27
Thanks Demian! Looking forward to any tips you could share on upgrades. No rush...
One additional note: besides the glitches on TP5, I noticed several glitches in the monitor out signal as well (see att.), not sure if that's expected for a stock unit.
  Reply to this post
Boonton 1121 Audio Analyzer: some questionsHide this!Advertise here!
Thread Tools
Boonton 1120/1121 Distortion Analyzer tweaks 1audio Equipment & Tools 169 20th July 2020 01:29 AM
Boonton 1120 and 1121 filter cards 1audio Everything Else 3 4th December 2016 04:33 PM
Boonton 1120 analyzer reads Incorrect Voltage wayle45 Equipment & Tools 1 30th October 2015 04:40 AM
FS: Boonton 1121 audio analyzer jackson7575 Swap Meet 0 1st September 2011 01:23 PM
Boonton 1120 audio analyzer Matyeo Swap Meet 1 8th April 2007 04:57 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
