Equipment & Tools From test equipment to hand tools
What does this PSU feature do?
Thread Tools
Old 6th February 2021, 02:37 PM   #1
miaulon is offline miaulon  Germany
Default What does this PSU feature do?
Hi everyone!
I recently got an old 1970s regulated power supply unit off of ebay. Ive tried looking for info on the manufaturer and had no success...
I want to ask you if anyone knows what is meant with the resistor connection thats printed on the positive outputs labeled V and I. This might be a newbie question, but i haven't had experience with this kind of PSU.
Thank you for your help!Click the image to open in full size.
Old 6th February 2021, 03:09 PM   #2
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
The purpose is to monitor the current flowing through the load.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 6th February 2021, 03:19 PM   #3
jjasniew is offline jjasniew  United States
jjasniew's Avatar
Why would it be "1/R"?
To set the current, i.e. hook up a 10 Ohm and you get 100 mA out when it's in constant current mode? Seems Bizarre -
Joe Jasniewski - PC>ZOUDIO AIO4CH> OB Lii Audio F15s w/ 18" assists.
Old 6th February 2021, 03:38 PM   #4
jjasniew: Yeah it just feels odd. I wish I could find a manual for it! I have the feeling I am missing something. But why make it go into constant current mode in that way if there is a switch to put the PSU into const. current though?
JonSnell: Maybe for an external meter? The PSU has a meter built in.
I suppose I'll have to re-cap it and just test to see what it does.
Old 6th February 2021, 03:57 PM   #5
That is for an external meter.
Old 6th February 2021, 04:51 PM   #6
Old 6th February 2021, 04:58 PM   #7
Mooly's Avatar
I have a couple of Farnell PSU's with a similar set up. The manual describes how to use the feature and why it exists. Yours will be the same...
Have a read at the pdf file.
  Reply to this post
What does this PSU feature do?Hide this!Advertise here!
Thread Tools
pcm1792 dac - use of the volume control feature BrianGT Digital Source 11 14th September 2003 06:45 PM
diyAudio Feature Request List Jason Everything Else 3 27th September 2002 09:59 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
