Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Equipment & Tools From test equipment to hand tools |
Thread Tools |
#11 | ||
![]() A classic VTVM is *always* a DC measuring instrument, just check classic schematics. The trick they use to measure AC is thanks to a probe, which does the rectification and conversion. They generally use 2 kinds: * the "RF probe" type. It uses a series cap which must also stand any DC voltage present so typically 600V rated, diode (usually Germanium) which generates a positive voltage and a high value series resistor (usually 4M7 or so) which in series with 10M input impedance scales doen the peak rectified voltage to RMS equivalent. ![]() *the "Peak to Peak" probe It uses a full wave rectifier-doubler. Sometimes a vacuum tube double diode is used, think 6H6, 6AL5 and similar. Meter panel has a Peak to Peak scale, and old TV schematics included waveforms and their PP values. So in a way, "DC testing witha battery" is still valid, as long as your AC probe is not damaged. Quote:
Design/make/service musical stuff in Buenos Aires, Argentina, since 1969. |
#12 | |
Did you look at the documentation?? This is an AC-ONLY amplifier meter. It will read to 0.03V FS which is well beyond an "RF probe" on a DC meter. It is a cheap version of the Ballantine 300 or the H-P AC-only meters. (Or multisync's Stark tube AC millivoltmeter.) Last edited by PRR; 4th December 2020 at 04:49 AM. |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Eico NOS Mdl 232K VTVM Peak-to-Peak VTVM KIT UNOPENED | HolySmokes | Swap Meet | 0 | 27th January 2012 11:01 PM |
diy Heathkit VTVM probe... | sklimek | Parts | 11 | 3rd December 2010 12:11 AM |
Battery Question vs VTVM | Alaska Bill | Equipment & Tools | 5 | 27th November 2010 05:32 AM |
HP 410B VTVM (refurbished and recalibrated) | n_maher | Swap Meet | 3 | 23rd September 2008 06:23 PM |
Is a VTVM useful? | d1camero | Tubes / Valves | 10 | 31st January 2008 06:12 AM |
New To Site? | Need Help? |
