BKPreicsion 1672/3 triple output power supply
Does any kind soul have a service manual or schematic for this bench supply? I have the 1673 version. It is displaying random voltage and amps on the master side displays, Output I\V is fine referenced to the slave side display but I want to find and fix the issue.
Owners manual attached for model reference.
  • 1672_manual.pdf
I dropped bk a note requesting the service manual or schematics earlier. We will see if that gets me anywhere. Aside from the display issues it works well but the display coupled with the transformer looking a little worse for wear makes me want to be sure.
Schematics and repair parts
Took a little while, but in case these are useful to somebody else in the future I have attached all of the documents from BK for this model. The parts use BK references numbers but still, it's a start. The service manual will be helpful for troubleshooting the LED screen, nice clear document.
Owen
  • 1672 Cal Procedure.doc
  • 1672MOD_calib.doc
  • 1672_schem.pdf
  • 1672MOD_serv.pdf
