Equipment & Tools From test equipment to hand tools
DIY soundcard intended for measuring amplifiers
Thread Tools
Old 14th January 2021, 08:05 PM   #81
MagicBus is online now MagicBus  Greece
MagicBus's Avatar
Originally Posted by popeman View Post
That looks great!
Any chance of seeing the frequency response with 192kHz sample rate?
Here you are.
Old 14th January 2021, 08:27 PM   #82
popeman is offline popeman
Thanks!
Old 14th January 2021, 08:30 PM   #83
MagicBus's Avatar
Default The high gain preamp
As already said this is Rod Elliott's P158. All info is there. The layout is mine, hopefully performing close to the original. It applies only to the left input and it is SE. So, unbal input mode should be selected to make it work. Also the input of this preamp is DC coupled, no input capacitor. It is engaged with NEC UC2-4,5NU relays. They are supplied from the unused usb Vbus. For the DIYINHK I2S converter here is an easy hack: close to the usb port there is a provision for a three pin connector. I guess this was for selecting usb or external psu with a jumper. Conveniently, this can be used to take the Vbus and also to power the module with 3,3V using a proper gauge wire. See pic. Attached noise floor measurements with input floating free and attenuator full open. The orange line is the basic floor of the input for reference.
Old 18th January 2021, 02:18 PM   #84
Mark Tillotson is offline Mark Tillotson
What units are those measurements in ?
Old 18th January 2021, 02:29 PM   #85
MagicBus's Avatar
ARTA is set for dBFS if that is what you are asking.
  Reply to this post
DIY soundcard intended for measuring amplifiersHide this!Advertise here!
Thread Tools
Shoe Horn? (pun intended) chuyler1 Full Range 16 4th March 2011 07:49 AM
Designing a loudspeaker intended to use with a digital crossover Pagnol Multi-Way 16 8th April 2010 11:48 PM
Will this balanced PSU work as intended? Will Solid State 4 24th February 2009 09:41 PM
This PS should work as intended, right? cetoole Parts 0 10th January 2006 05:30 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
