Equipment & Tools From test equipment to hand tools
Inexpensive Soldering Station
Old 19th September 2020, 06:34 AM   #71
H713 is online now H713  United States
H713's Avatar
Originally Posted by stratus46 View Post
You're right about expensive for the handpiece but I can tell you I am running the same handpiece ("wand")
for more than 12 years and I bought it used on eBay. Don't tug on it and it will be fine.
Where can I find info on the DIY RF supply?
G
The DIY Metcal supply can be found here:
DIY Metcal 13.56 MHz RF Supply - Page 1
I've never done anything with it (I was impatient and bought an MX-500), but lots of people seem to have had good success with it. Shouldn't be too difficult by any means.
Originally Posted by wiseoldtech View Post
Right, I won't pay such a hefty price for something like those metcals.
No need to.
In my professional work through the decades, I've always used the WTCPT station.
We're talking 40 years of doing customer service work, in various shops that I ran and worked in.
And in several factories that I know, the assembly lines all had those Wellers.
All my colleagues at other shops in the repair business also used the WTCPT, and we all had Fluke meters on our benches.
It was "the standard" that we swore by.
Oh sure, at home through the years, I got by with a radio shack pencil iron, doing occasional fixing, but when I set up my basement service area, I went right out and got a new WTCPT.
That said, I'm content with what I use.
The WTCPT was a good station in its day. It's what any serious technician or engineer used for decades. Some might have used a Pace, or something like a Hakko 926, but the WTCPT was the standard for decades.
Most of the "graybeard" engineers I know who previously used Weller have long since moved to the Metcal because it improves both the speed and quality of the work being done. Just because the WTCPT works well and was the standard for 30+ years doesn't mean that it is still the best choice (it's also out of production).
Rock bands used to tour with Phase Linear 700s or Crown DC300s. That doesn't mean they're a good amp by today's standards. By the 1990s amps like the Crest Pro series (4801, etc) and Crown Macro-Techs had set a new standard. Companies like BSS and MC2 pushed that standard even farther. Is the Phase Linear 700 any worse a design now than it was in the early 1970s? Hardly, but our standards have changed. It's the same story with soldering irons.
Before you bash the Metcal too hard, I would suggest trying one. I was a skeptic too, but it's a very, very clever and beautifully simple solution to the biggest deficiency of older irons- temperature regulation.
Does it circumvent skill? Not by a long shot. Part of why it's worth it though is that it makes things that used to be very difficult and unpleasant are now a lot easier. Replacing parts on a heat-damaged PCB is much less risky. Replacing parts that are soldered down to a ground plane isn't quite such a chore.
They are expensive- no question. But as has been mentioned many times in this thread, used Metcals are available for a very reasonable price and there are even DIY power supplies.
Old 19th September 2020, 07:06 AM   #72
jan.didden is online now jan.didden  Europe
jan.didden's Avatar
Originally Posted by kodabmx View Post
I just came across this project on EasyEDA...
Anyone feel bored enough to build their own?
ATmega SolderingStation SMD v2 -
EasyEDA
So this is a open source project where lots of people are making money off!
Jan
Old 19th September 2020, 02:13 PM   #73
wiseoldtech is offline wiseoldtech  United States
wiseoldtech's Avatar
I'm not "bashing" anything.
I'm just not interested in purchasing another station, expensive or otherwise.
As for the WTCPT, when did it "go out of production"?
Because that's news to me.
The one I purchased brand new from Mouser is only 3 years old.
Bohemian Guru sagacious, professional.
Old 20th September 2020, 01:52 AM   #74
1audio is offline 1audio  United States
I have several eBay Metcals, all worked fine and were pretty reasonable. My first exposure to Metcal was a friend working at a company making pacemakers. Something where reliability is extremely important. One of its strengths is precise temperature with no overshoot. Another is the very fine control of the tip and frankly the cool handpiece with the hand much closer to the small tip. Its like comparing a fine tip sharpie to a fat magic marker.
I have had quite a number of irons over the last 50+ years. There have been repairs i could do with a Metcal that otherwise would have required complete dismantling of the instrument. My primary Metcal I have been using for almost 30 years now. I recently added the desoldering tool to it, which is pretty amazing to use.
Skill and technique are critical to any soldering project but the better tools can open up possibilities that otherwise aren't attainable.
Demian Martin
Product Design Services
Old 20th September 2020, 02:04 AM   #75
it seems Weller has retired the WTCP line : Weller Entry level is $172 and the next step is $650. The Metcals don't look so expensive any more. Especially since the current tips work with my vintage power supply.
Demian Martin
  Reply to this post
Inexpensive Soldering StationHide this!Advertise here!
SMD soldering station merlin el mago Equipment & Tools 15 24th May 2017 07:52 PM
Soldering Station GOR3 Equipment & Tools 12 20th August 2011 06:44 PM
Soldering tips for soldering station BEST PRICE, FREE SHIPPING, 15% discount vtech9815 Vendor's Bazaar 0 27th January 2010 04:40 PM
WTB soldering station prezden Swap Meet 6 28th November 2008 08:45 PM
This soldering station OK for smd? johnthedoctor Parts 16 9th May 2006 11:30 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
