Latest project is as per title.
it is basically just an inverting stage where base vs collector voltages are measured and sent to pc via usb and displayed.
the curves can then be compared for a match.
the base voltage is a simple pwm into an integrator.
i use diff amps to convert between micro 3.3v and collector 9 volt supply and then back to 3.3v for a2d converter.
Expanded the transistor matcher to do some different voltage simple curves too.
On the prototype I made the mistake of using same supply for pnp and npn, this caused spikes in pnp readings. So split the supply through two separate transistors and it works a treat now.
Waiting for new pcb's now.
- Design & Build
- Equipment & Tools
- Transistor matcher and curve tracer
