Equipment & Tools From test equipment to hand tools
USB sound card for noise measurements
Old 1st August 2020, 08:02 AM   #91
ginetto61 is offline ginetto61  Italy
Hi ! i got the power injection cable. No differences at all with different +5VDC power supply solutions
Therefore is not the power supply responsible for the card noise floor ... it is something inside the card itself ... i see 4 screws
File Type: jpg terratec _ powered by dc-dc converter.JPG (129.2 KB, 103 views)
File Type: jpg terratec aureon usb noise _ avg linear.JPG (130.4 KB, 95 views)
“Without music, life would be a mistake” ― Friedrich Nietzsche
Old 1st August 2020, 01:48 PM   #92
Vovk Z is offline Vovk Z  Ukraine
First two are really very similar, but the third one definitely looks much noisier.
Old 1st August 2020, 02:54 PM   #93
bucks bunny is offline bucks bunny  Germany
for me the last one looks less noisy
Old 1st August 2020, 03:48 PM   #94
Maybe something changed except powersupply?
Old 1st August 2020, 04:20 PM   #95
Hi i checked better with the card powered via usb cable by the laptop
From the attached pic i see the same noise floor more or less. So to me the noise floor is very card dependent and not influenced by the power supply.
If i want the -140dB i have really to change card ... and it is perfectly fine because this is a very cheap sound card. No surprise.
In the other post the first two graph have been obtained
1) 12V linear power supply and a dc-dc converter to provide 5V
2) 5V linear power supply coming with the usb injection cable
Old 1st August 2020, 04:25 PM   #96
Hi ! i notice now that i have not used the same dB range on the left ... so some graphs look noiser than the other ... but not enough for me to say that using an external power supply improves things significantly.
Maybe there is another dc-dc conversion inside the card ? and that sets the overall noise performance.
anyway there is a RMS value for noise on the graph (bottom left). Very similar in all cases.
The limits are clearly inside the card
Old 1st August 2020, 05:52 PM   #97
Maybe I was wrong, the last one actually less noisy but has to much "grass". It doesn't help for measurements. So easier to use first two. The last wants some clean.
Old 1st August 2020, 11:55 PM   #98
trobbins is offline trobbins  Australia
trobbins's Avatar
Are inputs shorted by the sockets (just in case there is a difference)?
Old 2nd August 2020, 04:12 AM   #99
1audio is offline 1audio  United States
The 1 KHz could be the USB communications getting back into the audio. Was the input shorted for these measurements?
Demian Martin
Product Design Services
Old 2nd August 2020, 07:55 AM   #100
Hi no inputs open
I have a question off topic
Is noise above 20 kHz really a problem for an audio device? Because sometimes there is high frequency noise
I start loving dc-dc voltage converters a lot they are cute
As i need a dual supply +/-24V i have seen converters providing that with switching at 150 khz i wonder if they could be a valid option
I say this because smps are more and more common on pro audio equipment
Thanks a lot to All again
  Reply to this post
USB sound card for noise measurementsHide this!Advertise here!
Sound card impedance measurements Ron E Multi-Way 16 25th June 2015 05:22 PM
Want to Buy a Laptop and sound card for Audio Measurements Magz Equipment & Tools 18 6th September 2012 10:33 AM
Sound Card for Measurements Marik Solid State 2 2nd January 2012 08:59 PM
Sound Card Recommendations (For Audio Measurements) dchisholm Equipment & Tools 5 16th July 2011 09:40 AM
How to protect sound card during amp measurements? okapi Everything Else 13 2nd September 2008 03:06 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
