Equipment & Tools From test equipment to hand tools
ThatMicPre - an open-source mic preamp
Old 24th June 2020, 09:55 AM   #11
BamboszeK is offline BamboszeK  Poland
BamboszeK's Avatar
Perfectionism can be a curse Sometimes also I catch myself at overthinking circuits that seem to work perfectly already.
I can recommend those three papers:
http://www.ianbell.ukfsn.org/EzTubeM...nding101v2.pdf
Grounding and Shielding Audio Devices
Pin 1 Revisited
Phantom power and grounding are really tricky matters.
Still can't decide if its ok to "tie" enclosure and signal grounds with LED and resistor when SW1 turns phantom off.
Old 24th June 2020, 10:20 AM   #12
ojg is offline ojg
Yes, and where to reference the 48V supply? GNDPWR or GND?
Old 24th June 2020, 01:18 PM   #13
BamboszeK's Avatar
According to first paper it's best to reference +48V to enclosure GND.
Latest version of my whole schematics is in attachment. There is a jumper so I have a bit of flexibility. Depending on the results of measurements I can tie grounds or leave them unconnected. Now fun part begins - PCB layout.
I don't have much experience with isolated DC/DC converters but got suggestion that is better to connect them.
By the way - I can't find BOM, what's P/N of lever switches you used?
Old 24th June 2020, 01:37 PM   #14
ojg is offline ojg
BOM is in the plots folder.
Switches are 200MDP1T2B2M6QE
That's a promising schematic. I have some tips for you if you start your own thread ;-)
Old 24th June 2020, 06:00 PM   #15
BamboszeK's Avatar
Oh right, my bad. Thank you.
If you want to generate pretty BOMs in KiCad I can recommend you that plugin - KiCad Interactive HTML BOM Plugin Demos | InteractiveHtmlBomDemo
Tips are of course always welcome - Balanced microphone preamplifier with effect loop
Old 25th June 2020, 07:38 AM   #16
ojg is offline ojg
Wow, that BOM tool looked really nice, thanks for the tip! I'll look into adding it to my project.
ThatMicPre - an open-source mic preampHide this!Advertise here!
[Open source] TINA The total open source Audiophile Player based on Beaglebone Black DragonWar PC Based 7 18th December 2016 02:31 PM
Ultimate Open Source XMOS USB-I2S: The source to end all sources. krfkeith Digital Source 4 14th June 2013 03:54 PM
Volume / Source selector - open source project ? AuroraB Analog Line Level 22 22nd September 2012 02:21 PM
Open call for suggestions on Open Source DIY Audio Design gfergy Everything Else 1 15th April 2007 07:33 AM
Open Source, Open Architecture! zenmasterbrian Digital Source 185 23rd February 2007 10:35 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
