Equipment & Tools From test equipment to hand tools
High pitched noise that isnt being picked up on scope?
Old 20th June 2020, 01:19 AM   #21
PRR is offline PRR  United States
PRR's Avatar
Originally Posted by MarcelvdG View Post
Not being able to change the triggering sounds very 1950's.
"the scope is DSO188."
DSO188, mostly $35-$47.
It may just be too small to set trigger mode, with human fingers....
Trigger mode: Auto
Size: 57 x 34 x 11 mm
Weight: 40 grams
Old 20th June 2020, 08:08 AM   #22
MarcelvdG is offline MarcelvdG  Netherlands
Apparently it has a suspend button: "At any time, the waveform display (pause function) is frozen". If it then only displays the last trace it has captured, you may be able to see something that's too small to trigger on.
Old 20th June 2020, 09:17 AM   #23
Mooly's Avatar
I don't think you stand much chance of seeing this on the scope you mention, but if it is audible then it should be pretty easy on a conventional scope of decent bandwidth if you handle the controls correctly.
Old 20th June 2020, 10:14 AM   #24
phofman is offline phofman  Czech Republic
I do not know in this case, but often faint signals are audible because ear is averaging the noise. There are tests with audible signals encoded in dither. I do not think such signal would be discernable on single scope trace. But any soundcard with Arta/REW/even spectrogram in audacity will identify the peak easily.
Old 20th June 2020, 11:35 AM   #25
Mark Tillotson is offline Mark Tillotson
Have you compared it with a 15kHz test tone of the same perceived volume?
Is the scope in full bandwidth mode with probe set to 10x mode?
Could this be an intermodulation product from some higher frequencies beating?
Old 20th June 2020, 03:20 PM   #26
You can definitely look deeper with a narrower noise bandwidth, so just about any kind of spectrum analyser (hardware, software or biological) will beat a scope when it comes to detecting faint tones in noise. Still, you usually need more SNR to properly trigger a scope than to see something on a single-shot trace.
Old 22nd June 2020, 02:27 AM   #27
givemeyoursoul is offline givemeyoursoul
Originally Posted by laserscrape View Post
There is a high pitched ringing (~15khz) coming from my system which seems to fluctuate in volume slightly, almost like tinnitus , which I assumed it was after checking on scope and seeing absolutely nothing.
But after checking more thoroughly it is definitely the system, test tones of any frequency show up clear as day, rapidly changing waveforms like music or noise still show up clearly even if the scope cant track them.
How could it be that this noise is not being picked up at all on the scope?
Also I could still hear the noise through the headphones as the scope was attached.
"The capacitors in the 35th precinct are screaming..."
  Reply to this post
High pitched noise that isnt being picked up on scope?Hide this!Advertise here!
high-pitched noise from vox amp theinkysquids Instruments and Amps 2 12th January 2020 02:11 AM
Xonar DX high pitched noise snow43 PC Based 6 19th June 2016 11:29 PM
High pitched noise heard in my Hyundai loninappleton Car Audio 0 16th December 2010 07:04 PM
Marantz 2235B with high pitched noise ... tchiwam Solid State 2 31st October 2010 03:43 PM
high pitched noise candyman122 Car Audio 7 7th January 2010 02:13 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
