Equipment & Tools From test equipment to hand tools
Fried xover connecting scope
Old 9th June 2020, 12:25 AM   #1
foranobject is offline foranobject  Canada
Default Fried xover connecting scope
Playing sine wave into xover. Output of xover connected to scope channel 1 and input to amp. When I connected channel 2 to amp output, something fried in the xover. Why?
Old 9th June 2020, 12:32 AM   #2
rayma is offline rayma  United States
Is this an electronic crossover? Were both of the probe ground clips connected to ground?
Is the amplifier's output bridged, or ground referenced?
Old 9th June 2020, 12:55 AM   #3
It is (or was) a DSP crossover. I connected the scope ground of channel 1 to the shield of the XLR output on the xover. I connected channel 2 ground and signal to speaker wire coming out of the amp.
Old 9th June 2020, 01:13 AM   #4
Mark Tillotson is offline Mark Tillotson
The output will be bridged - you should never assume any speaker output is ground, some are, some aren't, and black/red colour code does not imply black is ground. Hopefully its just a fuse you have to replace.
Old 9th June 2020, 01:47 AM   #5
Unbalanced probes should not be used for floating measurements (except under very
specific conditions, by an expert). There's a good reason it's called a "ground clip".
Fried xover connecting scopeHide this!Advertise here!
DSO150 - a poor 'scope, but is it enough 'scope? bugbear Equipment & Tools 14 5th June 2018 03:13 PM
USB Scope - Real scope and not too expensive Algar_emi Equipment & Tools 11 16th March 2010 11:40 PM
Great deal on Digital scope. Is this enough scope? hifimaker Pass Labs 1 1st May 2007 09:59 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
