Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Equipment & Tools From test equipment to hand tools |
Thread Tools |
#191 |
Hi,Bart
My win98se is freshly installed. via copying the win98se setup files to the ssd C:\WIN98SE(c: dos6.22 and upl software already installed),then run SETUP. If SSD is used, after the win98 setup first reboot ,must be use win98 boot floppy disk boot system ,then type:SYS A:C:,after the above operations ,the win98 system installation can be completed. In win98se system ,run floppy disc :upl 3.06 1 and 2,then use win98 boot floppy disk(your win98updated files already copyed to this fdd a:\) boot system ,then type:updupdated.bat. reboot,ok! I can use UPL in win98 now . Upper mem :total 196.544k used 32.704k free 163.840k . (B10 NOT INSTALLED,I DON’T have any options installkey ). The confusion is that the upl run in win98 system seems instability. Best Regads. CSKG |
#192 | |
Could you try using one of my images? just want to rule out a bad windows install. You can use paragon to flash the image on the cf card and then restoring the mbr like you mentioned with sys c: I’ll set up a test with your type of motherboard over the weekend to judge instability. Kind regards, Bart |
#193 |
Hi,Bart,
Yesterday i mod the autoexec.bat and config.sys,Since then ,the system seems to be very stable. Autoexec.bat : delete<mode con codepage prepare=((850) C:\WINDOWS\COMMAND\ega.cpi) mode con codepage select=850 keyb be> Config.sys: delete<Country=032,850,C:\WINDOWS\COMMAND\country. sys> May be mod to <keyb us> <country 001,850>,it also will work.I didn't try. Kind regards, CSKG |
#194 |
Hello ,
yesterday I got an UPL and a scope from a friend . The UPL is in very good optical condition but channel one is not working in the correct way . Signal is distorted and fluctuating . Input relay with bad contact ??? and which is the right one , K3 ? On the analog/analyser pcb are no designations for the parts . Kind regards , Alexander .
No reason to get excited : Jimi Hendrix . Last edited by RE 604; 25th February 2021 at 08:29 PM. |
#195 | |
First thing i would check is the selftest, if you are able to run it, it requires the B10 option. Perhaps there you could find more clues to what search next. Kind Regards, Bart |
#196 |
Hello Bart ,
thank you for your answer , but the UPL made a selfrepair ![]() I measured channel one with the Victor 1khz generator and channel two with the UPL . Kind reards , Alexander .
No reason to get excited : Jimi Hendrix . |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
FS: Rohde&Schwarz R&S UPV DC to 250KHz Audio Analyzer | axismundi | Swap Meet | 4 | 8th August 2020 08:08 AM |
LCD Backlight for Rohde & Schwarz UPL? | ampexperts | Equipment & Tools | 149 | 26th April 2020 02:03 PM |
Rohde & Schwarz UPA3 analyzer | audio king | Equipment & Tools | 1 | 10th December 2016 11:38 PM |
Rohde-Schwarz-UP300 audio analyzer | Bonzoro | Swap Meet | 12 | 7th September 2016 05:40 AM |
Rohde & Schwarz UPV Audio Analyzer | c1ferrari | Equipment & Tools | 23 | 29th March 2015 08:36 AM |
New To Site? | Need Help? |
