Equipment & Tools From test equipment to hand tools
PCB cleaning with toothbrush
Old 23rd February 2020, 12:34 PM   #1
cbueche is offline cbueche  Switzerland
Default PCB cleaning with toothbrush
Hi all,
my Oral toothbrush's planned obsolescence came up last November. The battery just didn't hold the load anymore and swapping it is possible but well.... I went for a new one (Philips time time). Anyway, I had the idea to use the old brush to clean solder flux, and it works very well. Dispense some isopropyl alcohol on the PCB, start your toothbrush on it and gone is the flux, much easier than by any other method I tried. A second passage eliminate the flux haze and the PCB is nicer than new.
As the battery was dead, I opened the brush as explained here, removed every electronics and the dead battery, and soldered two wires to the motor's taps. It takes 1.2V at about 1.5 - 1.6 A from my lab PSU and works perfectly.
Charles
Old 23rd February 2020, 02:20 PM   #2
randytsuch is offline randytsuch
Very cool idea. Anyone who uses electric toothbrushes must have an old one around that doesn't hold a charge.
I would manually brush and then blot with a papertowel but I'm pretty sure your method would work better.
My system is here
randytsuch system
Old 23rd February 2020, 02:40 PM   #3
CG is offline CG
That is a fine idea! I will try that next time.
I’ve been using denatured alcohol and cotton swabs. Out with the swabs now.
Instead of a second alcohol wash, I’ve had better luck using a foaming bathroom cleaner followed by hot water.
Old 23rd February 2020, 02:47 PM   #4
wgh52 is offline wgh52  Germany
Originally Posted by cbueche View Post
...I opened the brush as explained here, removed every electronics and the dead battery, and soldered two wires to the motor's taps. It takes 1.2V at about 1.5 - 1.6 A from my lab PSU...
Hey Charles,
thank you sooo much for sharing you excellent ideas!
Winfried
Old 23rd February 2020, 05:37 PM   #5
RJM1 is offline RJM1  United States
I save regular old tooth brushes for this, they're great for getting between the pins of small pitch
connectors and leave no cotton swab remains that have to be picked off from the sharp edges.
Old 24th February 2020, 06:32 PM   #6
Mark Tillotson is offline Mark Tillotson
Just don't get it mixed up with your actual toothbrush!
I find that rosin tends to accumulate on a toothbrush after a number of uses and its good to rinse it off into a paper towel occasionally with pcb-cleaner, otherwise the brush tends to smear rosin about rather than remove it.
Old 24th February 2020, 07:29 PM   #7
ferret is offline ferret  South Africa
ferret's Avatar
I have an old AA battery powered toothbrush that I use the same way (Colgate) and the great thing is if the brush is pulled off, the metal "driving" pin can also be used to clean thick flux (light pressure only) in hard to reach places. Old dental tools also have their uses in getting into hard to reach places.
Ferret. - Gaya rules
Old 25th February 2020, 02:21 PM   #8
Vovk Z is offline Vovk Z  Ukraine
- you have to clean brush with pcb-cleaner after every time you use it (sorry Mark, I don't wanted to be Captain Obvious ).
PCB cleaning with toothbrushHide this!Advertise here!
PCB cleaning myleftear Construction Tips 20 24th January 2020 12:21 AM
Cleaning the lab... jcastellano Swap Meet 8 26th November 2018 05:14 PM
What's the BEST pot cleaning spray available in the USA? Professor Bizzt Equipment & Tools 19 28th August 2015 07:00 PM
Cleaning up jackinnj Construction Tips 5 22nd August 2009 12:37 AM
Cleaning pwc's colden Parts 1 29th January 2003 07:33 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
