Equipment & Tools From test equipment to hand tools
Need USA citisen help to buy pliers from ebay.
Need USA citisen help to buy pliers from ebay. Please consider donating to help us continue to serve you.
Old 28th March 2020, 02:27 AM   #71
FriedMule is offline FriedMule  Denmark
To pull out cable protectors?
Please bear with me. English is self taught and it may look like I have ignored your reply. But please know, I am doing my best, but may overlook something.
Old 28th March 2020, 02:49 AM   #72
jfetter is offline jfetter  Costa Rica
jfetter's Avatar
For installing new cable protector ( strain relief ).
I'm Considering going back to this style as opposed to the IEC entry.
"You never want a serious crisis to go to waste. And what I mean by that is an opportunity to do things that you think you could not do before. Rahm Emanuel.
Old 28th March 2020, 02:53 AM   #73
Yes it may be a great tool to own, the strain reliefs (thanks for the right word:-) can be a nightmare to remove or install. I do prefer the IEC because it's really flexible, you can chose length, socket to any country, you do not have to fight with the cord while transporting the unit and so on:-)
Old 28th March 2020, 05:40 AM   #74
Dave Zan is offline Dave Zan  Australia
Originally Posted by SyncTronX View Post
And then the middle tool,
I'm not sure what this tool actually is?
A chain tool, to press out the pins to "break" the chain, and press back pins to connect chains.
Best wishes
David
Old 28th March 2020, 05:40 AM   #75
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
That is a tool to open chains sir. Like the ones on bicycles.
I see two people on the globe pushed "enter" on the same time
It's only audio. Member of the non modular PCB design committee
Old 28th March 2020, 08:25 AM   #76
jfetter's Avatar
I remember it was under $5.
Old 29th March 2020, 03:32 AM   #77
1audio is offline 1audio  United States
Does it work well with Heyco strain relief's? its lots cheaper than their tool.
Demian Martin
Product Design Services
Old 29th March 2020, 09:27 AM   #78
jfetter's Avatar
I've used it a few times and it works great. I use it old guitar amps and my own prototypes.
It puts a proper 'crimp' in the cable that is difficult to do with pliers.
Keeps the heyco relief looking new and professional.
Old Yesterday, 11:54 PM   #79
SyncTronX is offline SyncTronX  United States
SyncTronX's Avatar
Thanks David
Originally Posted by Dave Zan View Post
A chain tool, to press out the pins to "break" the chain, and press back pins to connect chains. David
Danke jean-paul
Heck, I had that sitting around for the longest time no knowing what kind of tool
that is. Holy Cow, I need to get a new bike chain as the old one broke and the
good folks at the bike shops want something like $135USD for chain installation
plus the chain! They were willing to sell me some POS chain tool that might
work only once.
I assume I just buy a correct chain or slightly longer chain than I need and punch out
the links I don't need, then install the master link, stick the chain on the bike and
go.
I should probably measure everything first, before buying a chain. Or take the bike
in and buy a quality chain and install myself.
Thank you gentlemen.
STRAIN RELIEF
Well now I know what that tool is now also. I have been using Needle Nose vice grips for this.
I would use the big standard vice grip to set the strain relief, wait, then after the set, quickly
use the neele nose vice grips to stick it through the hole. Yes, even if I have a too small
ID (where the wire go though) I've been known to use a dremel cutting burr to widen
the ID inside of the strain relief. I don't have every size in stock...and it's good to use
up what is in stock first.
I should ask at my local surplus machine tool, aircraft parts place if they have one.
-- Sync
Need USA citisen help to buy pliers from ebay.Hide this!Advertise here!
Heyco strain relief pliers mazur Parts 7 21st August 2015 02:09 PM
Tronex Cutters and Pliers (USA Made!) PedroDaGr8 Equipment & Tools 3 30th September 2014 05:03 AM
eBay DAC kit jul059 Digital Line Level 4 6th May 2012 08:28 PM
3KingsAudio.com 5% Off Entire Order - eBay Prices without the eBay Hassle 3KingsAudio Vendor's Bazaar 4 24th October 2010 02:48 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
