Equipment & Tools From test equipment to hand tools
Need USA citisen help to buy pliers from ebay.
Old 26th March 2020, 06:31 AM   #61
SyncTronX is offline SyncTronX  United States
SyncTronX's Avatar
Here is a pic of my favorite bender pliers,
complete with box joint that never gets
wobbly and keep the jaws centered.
You vary the radius by where you grip
the wire to be bent. I like it for resistors
or other parts with leads that bends critical.
The "Three tools on Napkin" are great vintage tools.
The adjustable wrench top, the Merit fence tool
wrench to the right. And then the middle tool,
I'm not sure what this tool actually is?
It looks to hole punch centered for various sheet metal
thicknesses. Or maybe a nail removal tool from horse shoes.
Finally, I've tried to document the first instance of CyberSex,
before the term was even defined.
-- Sync
Old 26th March 2020, 07:56 AM   #62
FriedMule is offline FriedMule  Denmark
Sorry had to run. I have a wrench like the one at the top of picture two, it's still working:-)
The small pliers, are they any particular brand?
Please bear with me. English is self taught and it may look like I have ignored your reply. But please know, I am doing my best, but may overlook something.
Old 27th March 2020, 12:29 AM   #63
1audio is offline 1audio  United States
For parts forming for through hole this has been the go to for 40+ years: Resistor Lead Bending Tool - TOL-13114 - SparkFun Electronics
The tools look like Xcelite or Diamond tool. Both excellent.
Demian Martin
Product Design Services
Old 27th March 2020, 12:32 AM   #64
WOW thanks! That's genius and simple!
May I please ask what other tools you usually have at your bench?
Old 27th March 2020, 12:55 AM   #65
SyncTronX's Avatar
1Audio,
I've seen those just wondering if they are radiused where you bend the
lead? I've gotten accustomed to mine and have never had issues with it.
Though I should have one of those red plastic bending tools on the bench,
as it would save time once you have your lead spacing for through hole.
-- Sync
Old 27th March 2020, 02:23 AM   #66
They are radiused and in .1" increments. I have 2 sizes of the red ones and a green one that is only 1/4W parts but a larger range.
On my bench is an array of tools, below. Its overkill but will handle many things.
The pliers/cutter are from ETM. They were surplused out of Lockheed in the late 1980s. no longer made, the company now makes dental tools and they are $$$. The tray has a lot of different tweezers. The white think is a Clauss No-Nik, possibly the best wirewrap wire stripper ever. The electric screwdriver is essential i think and Broppe are the best I have found. They can be had from eBay for a very reasonable price. Metcal soldering iron and desoldering tool. The gold cylinder is a precista solder sucker. before the Metcal it was the best tool for removing solder. It was the only one adequate to multilayer PCB's or ground planes. Again, not made for years. There are more specialized tools, some used only once, but this is typical if you do this stuff a lot.
Ask away if you have any questions.
Demian Martin
Old 27th March 2020, 03:22 AM   #67
LOL that's a fairly large collection, but as you say, when you do it for a long time, do one get more tools, also "one time usage". Thank you for making so much work, just to reply to my question!! :-)
The white tool you write about to wire stripping, is that the one in the left most lower corner?
Do you repair cobber traces, what do you use for that?
Old 27th March 2020, 05:04 AM   #68
The white tool is the No-Nik. They come in a number of sizes for specific wire gauges.
I usually add a wire when a trace is damaged.
Demian Martin
Old 27th March 2020, 05:15 AM   #69
Okay thanks, I once saw a person on YouTube who did replace the trace with new thin cobber, it was a fantastic result, almost looked like it had never been damaged! :-)
He used some sort of micro chisel to scrape and dig down under the trace.
Old 28th March 2020, 02:26 AM   #70
jfetter is offline jfetter  Costa Rica
jfetter's Avatar
This is a most important tool if you restore old amplifiers.
"You never want a serious crisis to go to waste. And what I mean by that is an opportunity to do things that you think you could not do before. Rahm Emanuel.
Need USA citisen help to buy pliers from ebay.Hide this!Advertise here!
Heyco strain relief pliers mazur Parts 7 21st August 2015 02:09 PM
Tronex Cutters and Pliers (USA Made!) PedroDaGr8 Equipment & Tools 3 30th September 2014 05:03 AM
eBay DAC kit jul059 Digital Line Level 4 6th May 2012 08:28 PM
3KingsAudio.com 5% Off Entire Order - eBay Prices without the eBay Hassle 3KingsAudio Vendor's Bazaar 4 24th October 2010 02:48 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
