Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Equipment & Tools From test equipment to hand tools |
Thread Tools |
#371 |
I didn't do in-depth measurements, but when I turned on phantom power, a lot of ICs smoked, so I recapped the entire 1820m and replaced some of the JRC2068 with OPA1612, except on the headphone output. That box got really hot, probably greatly contributes to the demise of the cheap caps.
#372 |
Actually anyone can order from ISMOsys and the price is per unit. I had 4 ES9822 Pro arrive this morning and they took about a week to get here from the date they were ordered. I too was surprised at how cost effective these ADCs are given their reputed performance.
Whether or not you are eligible to sign an NDA for the data sheets is another thing but that's up the people at ESS. It doesn't hurt to try. If you have a company email/name or website, of your own, you can go through that would make it easier.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction. |
#373 | |
![]() ![]() Hp
FFT Analyzer & Generator at www.hpw-works.com |
#374 |
I will have to contact the ISMOsys representative and ask what kind of data I'm allowed to show. I can't see why my own measurements would be against the NDA as stereophile can perform measurements of gear containing ESS parts.
Without rereading the NDA I do remember there being some section on this and it wasn't promising. Needless to say if it performs well then I can surely say it performs well, go out and get them for yourselves. What I can say is this chip is very new, even to ESS. I get the impression that, following the fire at AKM, they rushed to get this to market to fill the sudden gap.
#375 |
I saw the NDA form on their web but I could not see the actual NDA... or?
More distortion to the people! Timing . . . . is paramount. |
#376 |
They send you the actual NDA to fill in.
#377 | ||
Stereophile is not under NDA, while testing official gear.. while developer is on NDA and may not able to share the good or even ugly behavior ![]() Funny will be the Hyperstream modulation against the SDM of AKM. While the noise on ESS is almost a step lower. This means also it is the inverse function of the ESS Hyperstream DAC! Quote:
Some are already nervous, while AKM ADC get's rare on sky ![]() Hp
#378 |
I have not seen mentioned ADS127L01. The syn08's measurements look quite interesting.
#379 |
Indeed, the ADS127L01 looks almost to good to be true
![]() I have to admit, after quite some experimenting with, I don't really understand how this ADC is working in frame mode, in particular at 384KHz. At 384KHz it works perfectly with the master clock set to 12.272MHz, oversampling set to x32 and the bit clock set at 24.576MHz. Question is, who's feeding the output at that bit rate, doesn't make much sense to me, I would expect the master clock to be larger (double) or at least equal to the bit clock. Must be some sort of double buffering inside that is not mentioned in the data sheet. |
#380 |
IIUC the bitclock just reads out samples from the internal buffer. 32 bits are read from each of the 1-channel chips, the master clock seems just right to clock 32 bits into the output buffer in one frame.
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Current thinking :) on Audio-grade vs Standard grade Toroids in PSU!! | tonewheelkev | Power Supplies | 40 | 21st January 2020 07:30 AM |
AK5572, a new hope for diy Audio Analyzer? | mtoc | Equipment & Tools | 0 | 5th July 2016 08:38 AM |
FS: Digital Audio ICs - ADCs, DACs, SRCs, other stuff.. | len_scanlan | Swap Meet | 0 | 29th December 2011 09:40 AM |
Audio humor. Wattgate 381 Audio Grade Duplex Socket | Pano | Parts | 18 | 17th March 2010 08:04 PM |
Rebuilding a DAC Audio grade or Computer grade caps? | gto127 | Digital Source | 0 | 28th January 2009 09:17 PM |
New To Site? | Need Help? |
