Equipment & Tools From test equipment to hand tools
ADCs and DACs for audio instrumentation applications
Thread Tools
Old 24th July 2021, 10:40 PM   #751
MagicianT is offline MagicianT  Canada
Unbelievable, on-screen data update rate crazy fast.
Check this out:
MCP356X Linearity test. - YouTube
It looks so slow, 10 times or even more? How it could be? ADC sampling rate is actually higher, 62.5 kHz vs 48 kHz. FFT-32k takes 0.5 sec just to fill up an array. Certainly, I can use smaller size, 8.192k or 4.096k and accelerate "visual" responsiveness, but I 'd lost noise flour. My ADC shows about -132dB ground line, vs -160dB . To get -28dB down, FFT has to be enormously bigger, 20x times or so, up to 512k.
What I'm missing? Same sampling rate with PCM4202:
pcm4202 62 5kHZ - YouTube
Video with jumping magnitude by 1dB/step also shows quite fast settling time, but I doubt your ADC is running at 5 Msps?
Old 25th July 2021, 04:59 AM   #752
IVX is offline IVX  Ukraine
IVX's Avatar
MagicianT I'm not sure if you asking me but my setup was:
AP analyzer generated digital sine 24/48k, next SPDIF to my PC, and play that sine with Cosmos DAC(that device includes switchable LPF 1k and 10k to produce ultra-clean 1k/10k sine). 10Vrms from Cosmos DAC goes to Cosmos ADC XLRs inputs, 32/48k ADC result goes to the PC back to make there FFT 64k-bins and to resend by SPDIF 24/48k ADC result to the AP.
Let's do smth nearly impossible!
E1. https://discord.gg/AAus72ZEpu
Old 25th July 2021, 05:31 AM   #753
IVX's Avatar
I just did add the I2S connector footprint that was asked by PM 5 min ago
PS: frontend resistors are Susumu RR1220PD and CSR02027, opamps OPA1602, power Monolithic Power Systems and Ti, USB bridge CT7601CR as a slave, ES9822 as master. The USB power has a soft-start, hence, ADC can run even with a smartphone if needed.
Old 25th July 2021, 05:49 AM   #754
trung224 is online now trung224
Great. The cosmos ADC can now easily be used with DSP board like freeDSP Aurora or miniDSP miniSharc.
Old 25th July 2021, 05:53 AM   #755
IVX's Avatar
Thank you for the idea!
PS: This picture shows how the gain control is actually implemented.
Old 25th July 2021, 08:33 AM   #756
electronic is offline electronic
Count me in for one
Old 25th July 2021, 12:08 PM   #757
O'k, 64k FFT than.
1. Sampling with 48 kHz it takes 64 /48= 1.33 seconds to fill a data array. Using 50% overlap 0.67 seconds. All digital data shown on a video updated 10x faster. Is video played at 10x speed?
2. With 64k FFT noway to get -160dB noise flour. About -140 at the best.
Old 25th July 2021, 02:29 PM   #758
IVX's Avatar
Originally Posted by MagicianT View Post
O'k, 64k FFT than.
So, the real world is fake anytime when we do not expect if something does possible?
Old 25th July 2021, 02:38 PM   #759
Check out DS: ADS127L01 SBAS607B APRIL 2016 REVISED SEPTEMBER 2016,
front page, and p.16-17.
Second law of thermodynamics says -160dB is impossible.
Old 25th July 2021, 03:32 PM   #760
IVX's Avatar
I did take a look at the ADS127L0, this is quite noisy ADC SNR 115db, if you'll check other ADCs(over 120db range) like PCM4222 or AK5578 you'll find much less than -140db noise-floor without Boltzmann constant trimming or elementary charge boosting in the flux-capacitor
ADCs and DACs for audio instrumentation applicationsHide this!Advertise here!
Thread Tools
FS: Digital Audio ICs - ADCs, DACs, SRCs, other stuff.. len_scanlan Swap Meet 0 29th December 2011 08:40 AM
Fundamental Questions: ADCs, DACs, I2S rsbonini Construction Tips 10 5th August 2011 09:40 PM
M-Audio Delta-44 and instrumentation under Linux suzyj Digital Source 8 27th July 2007 03:43 PM
Audio DACs, Instrumentation DACs. Brian Guralnick Digital Source 10 3rd November 2002 04:56 PM
DSD ADCs and DACs Brett Digital Source 8 14th October 2002 08:59 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
