Equipment & Tools From test equipment to hand tools
ADCs and DACs for audio instrumentation applications
Thread Tools
Old 23rd October 2021, 06:55 AM   #1341
altor is offline altor  Israel
This was my best result from 90389q2m with compensation.
At 7kHz THD is worse, but maybe due to ADC.
This ADC was a little bit noisy, I will try to re-test when Cosmos will come.
Regards, Alex
www.altor.co
Old 23rd October 2021, 10:05 AM   #1342
JensH is offline JensH  Denmark
Originally Posted by syn08 View Post
Jens, I was myself not able to bring a ES9038Q2M chip under -110dB THD+N at -1dB (with compensation), that was an heroic effort that included selecting the chip(s) (and destroying a couple of boards in the process). The -110dB i also the number that I see for the best commercial DAC implementations spec, although I don't think they are selecting the chips, so my boards (4 layers) could be 1-2dB less than optimal.
I believe -105dB @-1dB (without compensation) is a fair stating point to tweak the THD compensation, but you need to find out if it is the noise or the THD dominating the THD+N. I suspect it is the THD, so compensating may bring you to about the same numbers as above. I am using OPA1612 in the IV.
Originally Posted by IVX View Post
Just take a look to the ESS 9038Q2M demoboard and make the same, with compensation you'll see THD+N a bit less than -120db(depends on the chip noise performance), without compensation probably -117db(depends on the chip distortions performance).
Thanks for your feedback.
syn08: I measured THD, not THD+N. Anyway, the noise is relatively low, so I am primarily concerned about the THD for now. The noise can probably be reduced slightly by using a lower noise power supply. I will probably use an op-amp based AVCC to get very low noise.
I have tried with different IV's. The first one with 2xLME49990. The present one with a socket, having tested OPA1612 and OP1656. The results are very similar. I don't have a balanced to single ended op-amp on the output, relying instead on the differential input of the analyzer (RTX6001).
IVX: I am certainly far away from the -117dB without compensation. And that is what's worrying me a bit. My unit is 12dB worse. Could that be due to the circuit/layout or due to variation between chips?
altor: Your results look quite good. Do you have a number for the THD without compensation?
Old 23rd October 2021, 10:23 AM   #1343
IVX is offline IVX  Ukraine
IVX's Avatar
sure, I throw out about 4% of ES9038Q2M to get DR 123db(A) for 9038SG3(ES9038Q2M+AD8397 THD+N -117-115db).
Let's do smth nearly impossible!
E1. https://discord.gg/AAus72ZEpu
Old 23rd October 2021, 10:26 AM   #1344
IVX's Avatar
do not trust Spectraplus for THD+N ar any noise-related calculations, it is wrong.
Old 23rd October 2021, 11:31 AM   #1345
syn08 is offline syn08  Canada
syn08's Avatar
Interesting, how much is 0dBFS at your DAC output? For me, 0dB is always about 4Veff. It would also be interesting to see your numbers at -0.5dB, -3dB is quite low.
Old 23rd October 2021, 01:45 PM   #1346
Cannot find a screen shoot. Will measure with Cosmos.
2.8Vrms.
Picture above was at -3dB.
Regards, Alex
www.altor.co
Old 23rd October 2021, 01:53 PM   #1347
But I should mention, that I do not really believe in THD measurements less than 0.00008% with my AK5394 based ADC, because ESS compensation always compensate DAC+ADC harmonics.
Regards, Alex
www.altor.co
Old 23rd October 2021, 02:42 PM   #1348
The AK5394A is a great ADC, but at these levels a notch filter should be used.
Old 23rd October 2021, 02:51 PM   #1349
gentlevoice is offline gentlevoice  Denmark
@IVX: thanks for your clarification on my questions ;-)
Jesper
"... It is always possible to be friendly ..." HH the Dalai Lama.
  Reply to this post
ADCs and DACs for audio instrumentation applicationsHide this!Advertise here!
Thread Tools
FS: Digital Audio ICs - ADCs, DACs, SRCs, other stuff.. len_scanlan Swap Meet 0 29th December 2011 08:40 AM
Fundamental Questions: ADCs, DACs, I2S rsbonini Construction Tips 10 5th August 2011 09:40 PM
M-Audio Delta-44 and instrumentation under Linux suzyj Digital Source 8 27th July 2007 03:43 PM
Audio DACs, Instrumentation DACs. Brian Guralnick Digital Source 10 3rd November 2002 04:56 PM
DSD ADCs and DACs Brett Digital Source 8 14th October 2002 08:59 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
