Equipment & Tools From test equipment to hand tools
Curve Tracer or Audio Analyser?
Thread Tools
Old 25th November 2021, 12:03 AM   #71
kannan_s is offline kannan_s  United States
Send a message via Yahoo to kannan_s
What is the accuracy specifications? no mention in the specifications
Old 25th November 2021, 12:14 PM   #72
mbrennwa is offline mbrennwa  Switzerland
mbrennwa's Avatar
Is there (or will there be) any documentation on the command set/protocol that is used to talk to the board? It would be nice to allow using the board with custom software.
Old 26th November 2021, 03:51 PM   #73
benc is offline benc  United Kingdom
kannan_s:
We will publish accuracy specs soon, these are slightly more complex to define as the accuracy in pulsed mode is a quite difficult to measure directly.
Whilst it's easy to dump a few amps for 100us into a non-inductive resistor and measure pulse height using an oscilloscope, doing this at high enough resolution is beyond any oscilloscope I've come across (most of ours are 8 or 10bit, even a 12 bit scope wouldn't have enough accuracy to be meaningful).
Development of the calibration system for the CTL503 took a huge amount of time, and as mentioned earlier, it is carried out with a DMM and 4 resistors. It takes 10-20minutes at least to do, so we developed an automatic system and fixture to speed it up (closed box calibration). Here's a screen shot of the CTL503 calibration page in EPIC:
Ultimatley the accuracy of the CTL is largely defined by the temp-coefficient of internal resistors, and as you will appreciate producing an affordable unit does require some compromise. Still - in our experience - it is far more accurate than any legacy curve-tracer (short of a Keithley 4200).
mbrennwa:
Documentation is coming and we will detail the protocol as well, we have plans for an API at some point also.
Like most of our products, the heavy-lifting is done in the PC, so there is a fair complexity to interfacing to the unit - including some safe-guards regarding the HV PSU. We spent alot of time trying to make it 'bomb-proof', although time will tell how this works out.
www.electron.plus test instrument maker, hobbyist and ham (G1YWC)
Old 30th November 2021, 07:31 AM   #74
mbrennwa's Avatar
I am not worried about accuracy, since calibration should be easy in the software.
However, what about precision? What about resolution? Tracing an IRFP150 is different from tracing a 2SJ74. Many tracers will do one, but not the other.
Old 30th November 2021, 08:00 AM   #75
The highest 'Collector' resistor is 27K, the lowest 24R and the ADC converter is 24bit (less in reality), there is a compensation mechanism in SW to reduce/remove parasitic errors (such as those from the collector/ADC potential divider), so you can measure collector currents in the uA.
  Reply to this post
Curve Tracer or Audio Analyser?Hide this!Advertise here!
Thread Tools
DIY Curve Tracer avincenty Equipment & Tools 356 10th July 2018 09:30 AM
Curve Tracer Stefanoo Equipment & Tools 97 8th September 2017 03:01 PM
curve tracer barclaycon Equipment & Tools 7 6th March 2017 02:18 PM
GB for DIY Curve Tracer for PC Lazybutt Group Buys 190 25th November 2013 12:17 AM
Curve Tracer sdman Solid State 0 21st February 2012 02:36 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
