Equipment & Tools From test equipment to hand tools
Analog interface to get an audio analyser from a soundcard
Thread Tools
Old 1st November 2019, 12:39 AM   #11
trobbins is offline trobbins  Australia
trobbins's Avatar
I've battery powered my soundcard, and have a battery powered USB isolator, and can use a laptop, as means to suppress mains borne earth loop currents from the amplifier-under-test's connection between ground and mains PE.
For valve amps I renovate I make an effort to link input and output grounds with minimum opportunity for noise insertion in that link within the amp.
Other practical issues that can degrade the noise floor, as others have noticed, is to be careful of nearby noise sources (such as bench lamps) and connecting other mains powered instruments to the DUT.
Just saying that with a bit of care, single-ended test setups for some applications can provide a noise floor well under the DUT noise floor.
  Reply to this post
Analog interface to get an audio analyser from a soundcardHide this!Advertise here!
Thread Tools
Interface / Soundcard for ARTA DR ANALOGUE Equipment & Tools 0 13th October 2019 12:53 PM
FS: Millett Soundcard Interface -PCB + faceplates VictoriaGuy Swap Meet 1 14th January 2019 07:05 PM
Which tools - oscilloscope/logic analyser/soundcard for DIY audio products crestaboy Equipment & Tools 2 3rd February 2018 09:47 AM
FS: Soundcard Interface VT67 Swap Meet 7 4th August 2012 11:06 AM
Soundcard interface. Mr Evil Everything Else 5 12th July 2005 11:38 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
