Equipment & Tools From test equipment to hand tools
WBLNA - Wide Bandwidth low noise amplifier
Thread Tools
Old 12th October 2019, 08:14 AM   #1
Frex is offline Frex  France
Arrow WBLNA - Wide Bandwidth low noise amplifier
Hi all,
I designed some weeks ago a small tool to improve my noise instrumentation setup.
In fact, when doing wide-band noise measurement (well beyond what we can simply do with a sound card),
is is more difficult to measure low noise level.
One way is to use RMS measurement with an oscilloscope, but scope sensitivity doesn't go much less than a mV...
My latest AAPSU01 low noise PSU design is an example that can achieve low wide-band noise,
and so building this small tool has been motivate first by that.
So in practical manner, it's a small shielded box that include a low noise, high bandwidth and high gain amplifier.
The design specs are :
  • 20Hz to 20MHz measurement bandwidth (-3 dB)
  • 4th order Butterworth low pass filtering.
  • Individual +20 dB(x10) and +40 dB(x100) outputs BNC
  • 12 Vdc@50mA input supply.
  • Max input amplitude about 100mVpp (with 12V supply)
  • Output noise floor RTI ~ 12µVrms (Equal to En= 2.7nV/VHz)
  • Can handle +/- 20VDC input offset voltage (AC coupled)
  • Zin= 50 Ohms, AC or DC coupled (internal jumpers)
  • Fully shielded design.
  • Low cost design (full bom <30€ + PCB)
The design is based on LT6200-10 OPAMP from LinearTech (now AD).
It's a very high speed amplifier with 1.6GHz of GBW product
and less than 1nV/VHz of spectral noise density.
The full schematics is here : WBLNA_schematics
You can show below some picture of my unit and some measurements results.
PCB Kicad 3D view :
Picture of the finished prototype :
100ns pulse test input/output result :
So, i have published this projects as open source and it is available
to download on the GitHub repository here : \OnEAudioProjects\WBLNA
The project has been designed with Kicad 5.0.2
All original design files are available :
  • Schematics
  • Bill of material (with Mouser order codes)
  • Mechanical drawing
  • LTspice design files
  • Gerbers files
  • Panels stickers print
and more...
So i hope that will interest some people.
(Note that i have few bare PCB's available(4) , anyone interested can get one
with the panel stickers for 6€ worldwide shipping included )
Regards.
Frex
Old 12th October 2019, 08:30 AM   #2
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Frex, you keep surprising us!
Do you have an idea of the distortion of this amplifier up to say 50kHz?
Jan
Old 12th October 2019, 09:08 AM   #3
Hello,
I don't have done THD measurement on it, but LT6200-10 datasheet specs show very good THD figure
up to MHz range.I'll try to make some measurements if i found time.
Regards.
Frex
Old 14th October 2019, 09:54 PM   #4
Mark Tillotson is offline Mark Tillotson
The LT6200 1/f knee is around 1kHz, not unusual for a high speed amp, but not ideal for audio work perhaps?
Do you have a measured noise-floor plot?
Old 16th October 2019, 03:26 PM   #5
Hello,
It's not directly intended to audio stuff, but it can.
You can show on simulation of my design in LTSpice below
the noise spectra density between all bandwidth of 20Hz-20MHz.
It show an rms value of about 1mV, very near i had really measured on my prototype (1.2mV).
If you would take only audio bandwidth of 20Hz-20kHz, that would gave 31 µVrms that is 310nVrms RTI.
Regards.
Frex
  Reply to this post
WBLNA - Wide Bandwidth low noise amplifierHide this!Advertise here!
Thread Tools
3" Front horn - wide bandwidth S4m Full Range 14 27th July 2015 04:04 PM
Wide bandwidth class AB with 10mA quiescent? newvirus2008 Solid State 84 24th May 2011 10:53 AM
Recomendation Please-100W Wide-Bandwidth Amp LinuksGuru Class D 4 1st November 2009 02:22 PM
Recommendation Please-100W Wide-Bandwidth Amp LinuksGuru Solid State 0 30th October 2009 09:34 PM
Leach wide bandwidth preamp. beppe61 Solid State 21 22nd February 2005 03:46 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
