Equipment & Tools From test equipment to hand tools
REW soundcard calibration?
Old 10th August 2019, 03:57 PM   #1
daemonsgr is offline daemonsgr  United Kingdom
Default REW soundcard calibration?
Im a bit puzzled with the reading of the "soundcard calibrated" measurements.
The non-calibrated one makes more sense for me (especially for this setup).
Its from a normal UK room (built 150years ago?!), no treatment etc with two HM80 Yamaha monitors, no good placement..nothing (mic around 170cm away). I was just testing the PRM1 Mic and the Focusrite card.
How do you read a measurement like this? the calibration 'correction' make it flat.. ?!?!
Old 10th August 2019, 04:11 PM   #2
JohnPM is offline JohnPM  United Kingdom
You have saved a room measurement as a soundcard calibration. The soundcard calibration should be a measurement of a loopback connection from soundcard output to input, not an acoustic measurement. Soundcard calibration isn't needed for most interfaces, but it is a good way to pick up any monitoring that is active (which makes the measurements incorrect).
Old 10th August 2019, 04:17 PM   #3
Ha!!! very silly mistake!
I have multi-Ins and outs so I used a extra one for the loopback, but I didnt select the correct one... So the mic was doing all the work! heheh
Thanks a lot!
Old 10th August 2019, 04:18 PM   #4
Pano is offline Pano  United States
Pano's Avatar
^ What John said.
What you've done does clearly show you one thing; how repeatable, or not, your measurements are.
Take the Speaker Voltage Test!
REW soundcard calibration?Hide this!Advertise here!
Mic calibration Jonas83 Equipment & Tools 9 2nd May 2018 04:15 PM
Calibration Mic gigigirl Equipment & Tools 2 14th April 2018 02:38 AM
Help with calibration Viper_user Full Range 8 18th August 2012 06:28 PM
A Mic Calibration How-To cuibono Multi-Way 3 11th June 2009 11:10 AM
Copyright ©1999-2019 diyAudio
