Equipment & Tools From test equipment to hand tools
Distortion analysis - a thought experiment
Old 13th August 2019, 02:00 PM   #61
diyralf is offline diyralf
diyralf's Avatar
It is from AudioSience. I guess it is the analog oscillator. DAC are too bad :-)
Old 13th August 2019, 02:40 PM   #62
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Analog generator. It says in the screen shot ;-)
Jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 13th August 2019, 02:52 PM   #63
phofman is offline phofman  Czech Republic
I see, I did not zoom-in the diyralf's screenshot. I assume your screenshot is from an analog generator too. Please can you post also the digital generator, for comparison?
Old 13th August 2019, 03:20 PM   #64
jan.didden's Avatar
Well if I could, I would have one of those babies, but alas! But I will ask.
Jan
Old 15th August 2019, 07:56 PM   #65
DualTriode is offline DualTriode  United States
Jan,
A couple of thoughts about testing your super duper stuff.
Test the noise performance without the test signal, with the input shorted. Send the output through a 100 times gain known quality instrument amplifier. (OPA1612?) That output goes into your System 2 analyzer. Is the super duper stuff worthy? If yes then next.
If you are looking for better than -134dB 2nd harmonic take the SDS down the road to you neighbors APx555 that is good for -150ish dB 2nd harmonic. If yes then stop, else.
Or split the generator output send half to your DUT the other half to the inverting input of an OPA1612. Sum the outputs of your DUT and the inverted instrument OPA1612, the test input signal fundamental and harmonics will null. What remains is only the DUT error output. Send the amplified error output to your System 2 analyzer. See Figure 34 in the OPA1612 data sheet. This is the stuff of error correction.
http://www.ti.com/lit/ds/symlink/opa1612.pdf
Or I could be full of it.
Thanks DT
New out of the box unbalanced APx555.
Old 15th August 2019, 08:19 PM   #66
jackinnj is offline jackinnj  United States
jackinnj's Avatar
is there a "jealous" emoji out there?
Old 15th August 2019, 08:34 PM   #67
Jackinnj,
Funny thing. I was thinking of you the entire time I was typing stuff about noise measurement.
Distortion analysis - a thought experimentHide this!Advertise here!
Multi-amp thought experiment Moondog55 Multi-Way 31 13th June 2019 02:47 AM
The Chinese Room Thought Experiment thadman The Lounge 43 19th December 2012 11:53 PM
Just a thought experimentů no1herenow Multi-Way 29 23rd January 2012 06:35 PM
Who Wants To Be A Millionaire? (a thought experiment) thadman The Lounge 10 11th May 2011 09:54 PM
BIB thought experiment Brisso57 Full Range 3 27th January 2009 03:13 PM
Copyright ©1999-2019 diyAudio
