Equipment & Tools From test equipment to hand tools
What Volts and Amps power supply should I look for
Old 26th July 2019, 03:00 PM   #1
djn is offline djn  United States
djn's Avatar
Default What Volts and Amps power supply should I look for
Hi guys,
What size power supply should I look for? Actually I'm not sure what a power supply is used for on a work bench.
Old 26th July 2019, 03:09 PM   #2
FauxFrench is online now FauxFrench  France
The values for a bench power supply depend very much on the type of constructions you make. Very often you start with a 0-30V or 0-40V bench supply with some 2-3Amp capacity. They are not expensive. If you make amplifiers that need symmetrical voltages, then you can find symmetrical bench supplies but the price goes up. Depending on the amount you want to spend, a capacity of 5Amp is nice to have.
Do not expect that your bench supply can handle any voltage and current you may need in the future.
Old 26th July 2019, 04:13 PM   #3
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Experimenting If you just want to build projects then build power supplies as you need them.
Old 26th July 2019, 05:11 PM   #4
w5jag is online now w5jag  United States
A good start:
For tubes: old greifkits, Knight, etc., typically have a 6 volt heater line, adjustable bias, and adjustable regulated high voltage all in one box. These are inexpensive and a good way to go, imo.
If you are only going to work with solid state, 0-30 or 0-60 VDC would probably be okay. I have some that go up to 50 amps, some as small as a couple of amps. Depends on what you need them to do. A 3 or 5 amp supply would probably be okay to start with. At some point, you might also need a negative supply.
On or around my bench I have separate supplies providing 0 - 15 VDC; 0-30 VDC; 0-150 VDC, 0-400 VDC, and negative 0 - 125 VDC. I can improvise up to 900 VDC or so. It helps to have multiple supplies, as it is common to need different voltages simultaneously.
Adjustable output current limiting is also a useful feature.
You might also want to think about getting a variable transformer that can reduce your AC line voltage. These are typically called Variacs.
Hope this helps.
Win W5JAG
Old 27th July 2019, 05:31 PM   #5
djn's Avatar
I just pick up this for 40 bucks
Old 4th August 2019, 07:31 PM   #6
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
I built an amplifier test bed.
It has a power supply and crocodile clips on flying leads for applying power to pcb's.
On the output is a DC protection circuit so I don't fry my speakers.
PCBCAD51 download or CDROM 2019 version out now https://www.murtonpikesystems.co.uk
What Volts and Amps power supply should I look forHide this!Advertise here!
12 volt /5 amps off mains vs 12 volts/3 amps off battery power for mini-amp? Jaxhouse Power Supplies 3 20th June 2014 11:44 AM
+/- 85 volts symmetrical power supply xeclipse Solid State 3 23rd May 2010 05:29 AM
how to use 30 volts DC instead of split power Supply ali_moinuddin Pass Labs 5 2nd April 2008 10:34 PM
power supply question.... too many Volts? akimball442 Tubes / Valves 3 18th February 2007 04:12 PM
How to use a 220 Volt power supply at 12 Volts in the car? Mr. Old School Car Audio 3 10th March 2006 12:11 AM
Copyright ©1999-2019 diyAudio
