Equipment & Tools From test equipment to hand tools
Scanner for plates?
Scanner for plates?
Old 14th July 2019, 06:01 PM   #11
Destroyer OS is offline Destroyer OS  United States
Destroyer OS's Avatar
Scanner for plates?
I'll look into it.
I did figure I might have to place something for scale along with whatever I scan.
Old 14th July 2019, 07:18 PM   #12
Duke58 is offline Duke58  United States
There are free apps available where you can take a photo of an object and it converts the data to a digital file. I m made a faceplate for an amplifier.
Old 14th July 2019, 09:54 PM   #13
Gnobuddy is online now Gnobuddy  Canada
Originally Posted by Destroyer OS View Post
...you can buy an all-in-one printer for $200 with a 11x17" flatbed.
Ten or fifteen years ago, before digital cameras became commonplace, affordable USB scanners were fashionable home computer accessories. They aren't fashionable any longer, so check your local thrift stores - you may get lucky.
A couple of years ago, I found a nice Epson scanner in perfect working condition for $15 CAD at a local thrift store. I still have it, and it still works just fine. Even better, it works with my OS, Linux.
I found a good quality six-ink HP photo quality inkjet printer for $10 at about the same time. It's still in daily use, and it seems to be much better built than currently available affordable inkjet printers.
-Gnobuddy
Old 15th July 2019, 01:34 AM   #14
Scanner for plates?
I'll check on all of that. An app might work but I'd have to standardize the phone's position. I think a scanner sounds more simply...
Linux is always a plus. I'll keep an eye out. 11x17 is a little less common! I've started checking Craigslist.
Old 15th July 2019, 05:52 AM   #15
PRR is offline PRR  United States
PRR's Avatar
Originally Posted by Gnobuddy View Post
...affordable USB scanners were fashionable home computer accessories.
And before that: printer-port scanners!! Ugh!
Be cautious about mystery USB scanners. I have a sweet USB-powered one but the drivers were awkward and now long obsolete (I have not tried it in unix).
You want cheap and universal (but small): H-P C9900A. About the size of a book. About a 4x6 bed. One USB wire-- that's it!! To the host it looks like "storage device". You open it on the PC and see a blank folder. Press the scan button, a JPG file appears in the folder. Can take about a dozen scans. Better copy them off to PC storage because when you unplug it, they are gone. I found mine for $2 at a church sale. (Seems to hold value near $40 on eBay, even thoough quite old.) Obviously won't do for scanning big hi-fi amps, but is sweet to sit on the desk to scan notes and such.
Old 15th July 2019, 06:20 AM   #16
phofman is offline phofman  Czech Republic
Today most scanners being sold are in all-in-one printers. A3 all-in-ones are not expensive and can be quite useful even at home. Pre-owned start at $130 on amazon https://www.amazon.com/HP-OfficeJet-.../dp/B01JUCLLGK
Old 15th July 2019, 07:41 AM   #17
I had a printer-port Zip drive at one time (anyone remember Zip drives?) It was awful and hilarious at the same time - the parallel-port printer cable was heavier than the Zip drive, and very stiff, so the cable would drag the Zip drive all over the place, usually off the edge of the desk...
My experience is that older hardware - if it had Linux support when it was new - is much more likely to still be supported under Linux, than by recent versions of Windows. If it was sold when Windows 98 SE or Windows XP was state-of-the-art, it might still work under Linux, but it is very, very unlikely to work with Windows 10.
This isn't hard to figure out - Linux being open-source, someone will usually keep the drivers working as the underlying operating system evolves, either because they own that hardware, or they just like fixing broken things (drivers.) But proprietary drivers can only be made by the company that originally sold the device, and they have zero incentive to keep supporting a ten year old consumer device - all that does is rob sales from the new product they're trying to sell you!
HP and Epson printers and scanners tended to have excellent Linux support when new, which is one reason I took a chance on both those thrift-store finds.
-Gnobuddy
Old 15th July 2019, 06:04 PM   #18
Rather than using a larger scanner (which is certainly rarer and more expensive), why not stitch together two separate smaller images using free image processing software (like The Gimp on Linux, or any of the Photoshop-alikes)?
Perhaps it will be more affordable to scan large faceplates as two separate images, then stitch them together on your computer? A bit more work, but perhaps worth it for the flexibility, and the ability to scan things even bigger than 17". You can get nearly 22" from an ordinary 8.5x11 scanner with two separate images, and that will cover most home electronics faceplates, including 19" rack-mount devices, etc.
You would typically need to rotate one of the two images slightly to make sure both are perfectly parallel, and, of course, both have to be taken at the same scale (easy when they both come off the same flatbed scanner.) After that it's a matter of moving the images until they overlap perfectly, trimming off any excess, and merging the two into one single image.
To be clear, I've never used a scanner for anything other than paper documents, so I've never tried this myself.
-Gnobuddy
Old 15th July 2019, 07:03 PM   #19
Scanner for plates?
If I can find one that is flat enough to allow that to happen accurately, it could happen.
Scanner for plates?Hide this!Advertise here!
RCA black plates with writing on plates Tubebandit Tubes / Valves 13 28th July 2018 02:59 PM
Amplifier terminal plates (rear plates) source? JonesySA Parts 0 8th November 2014 06:26 AM
Vinyl Scanner? Nehesi Analogue Source 37 20th July 2011 08:29 AM
Fs: Canon Flatbed Scanner TheNoodPoopler Swap Meet 1 28th May 2004 07:07 PM
Someone with Enigma 3 and a scanner: Can you help me? Hybrid fourdoor Music 0 21st September 2003 10:22 AM
Copyright ©1999-2019 diyAudio
