Equipment & Tools From test equipment to hand tools
Oscillator coil with common wires?
Old 15th July 2019, 08:12 AM   #41
Elvee is offline Elvee  Belgium
Elvee's Avatar
I will test something else: a full-wave rectifier and a 200µA meter.
It will work, with a bit of luck, but 4 Ge or schottky will be required, because two drops of ordinary diodes will not be tolerated.
. .Circlophone your life !!!! . . ♫♪ My little cheap Circlophoneİ ♫♪
Electrify your daily life!!! ....⚡⚡ ELEKTRIA ⚡⚡
Old 15th July 2019, 10:53 AM   #42
Elvee's Avatar
The 200µA meter + 4 Ge or schottky works, and the scale is quite usable, even for ESR>10ohm.
The best remains 50µA + 2 schottky, but the difference isn't huge.
Here is the updated circuit:
Oscillator coil with common wires?-editedesr6-png
Oscillator coil with common wires?-esr6-jpg
Old 15th July 2019, 01:35 PM   #43
PhantomBox is offline PhantomBox  Venezuela
I found another two VU meters, from an old tube reel recorder.
They are the same 200µA. However, when I drop the resistor to 47K ohms, I get a full scale deflection.
Now I will get some small Schottky diodes and a few caps...
Old 15th July 2019, 09:39 PM   #44
Elvee's Avatar
Don't forget that Ge "crystal" diodes are also suitable (and even better than most schottky's) and could be easier to salvage from old equipments.
They include many two-digits 1N types, like 1N34, 1N70, european types, OA90 to 95, AA119, 143, etc, plus japanese 1Sxx, soviet types, etc
Old 16th July 2019, 02:11 AM   #45
PRR is offline PRR  United States
PRR's Avatar
"ALL" VU meters are 200uA. Unless they are very cheap 1mA units with a custom driver.
Needle-type VOMs come in $10 500uA and $50 50uA basic movement.
This one is 50uA for $33, and you don't even have to open it up.
https://www.amazon.com/Tekpower-TP72.../dp/B00MI6T0IW
(Oddly, it says 60uA on the switch?)
Another key clue is the fine print on the scale: "2K/V" is 500uA, "20K/V" is 50uA. If they don't actually expose a 50uA range on the switch, you can bust it open and connect direct to the movement.
This appears to also be a 50uA meter:
https://www.amazon.com/Tekpower-TP82.../dp/B00SLVPJSI
Oscillator coil with common wires?Hide this!Advertise here!
Attaching flexible leads to aluminum voice coil wires cyclecamper Multi-Way 1 8th September 2014 06:17 AM
Commercial Pre-Pre Amps for Moving Coil Cartridges (MC Head Amps) in Common Base tiefbassuebertr Analogue Source 8 11th December 2012 08:54 AM
Is a Fuzz Face a common-emitter or common-collector circuit? ninopelo29 Instruments and Amps 6 9th December 2011 01:38 AM
glue for voice coil wires malcontent Multi-Way 5 6th March 2007 01:12 AM
Conductors (I.C.'s, RCAs, internal wires, speaker wires) bigphil Parts 1 25th November 2005 06:47 PM
Copyright ©1999-2019 diyAudio
