Equipment & Tools From test equipment to hand tools
Oscillator coil with common wires?
Old 13th July 2019, 12:47 PM   #31
PhantomBox is offline PhantomBox  Venezuela
I guess 1N4148 will have to do then, for now...
The 22nF caps are polyester layer (salvaged from a really old Midas audio console), but the critical caps 1.5nF and 680pF are ceramic discs.
Old 13th July 2019, 05:40 PM   #32
Elvee is offline Elvee  Belgium
Elvee's Avatar
Here is the final, tested version:
Oscillator coil with common wires?-editedesr5-png
I have tested 1N4148's, and the circuit can be adjusted to accomodate them.
The only small inconvenient is that the left of the scale is more compressed, meaning resistances greater than 5~10 ohm become difficult to read, but that is not really problematic, because such a value already means that the cap has dried up.
I have tested ordinary ceramic caps: the 680p tolerates any type, and for the 1.5nF, only one posed problem: its losses were too high, meaning a reduced oscillator amplitude.
So, it is not too critical, but if you can find multilayers, it is preferable.
The 22nF is absolutely not critical.
To calibrate the meter you can use a new, good quality, large Ecap (1000µ or 2200µ) as a short-circuit reference, with known series resistors added.
First, you should leave the test terminals open, set R9 to its minimum resistance, and progressively increase the value until the meter deviation is reduced almost to zero.
Stop just before the actual zero.
Then, connect the reference cap directly (no series resistance) and adjust R1 for exactly the full scale deviation of the meter.
When that is done, your meter is ready to go, but if you want to have an idea of the scale, or write indications on the dial, you can connect various resistors in series with the reference and observe the deviation.
With 10 x1 ohm resistors connected in parallel, then in series, you can cover the whole 0.1 to 10 ohm range.
I think the original project has details on this procedure.
Note that the calibration/scale will be different if you change the diodes.
The circuit is designed for a 50µA meter having a total series resistance of 20K.
Other values would require modifications.
. .Circlophone your life !!!! . . ♫♪ My little cheap Circlophoneİ ♫♪
Electrify your daily life!!! ....⚡⚡ ELEKTRIA ⚡⚡
Old 14th July 2019, 03:21 AM   #33
I'm not really sure how much µA my meter has. I took it from an old professional audio console, it says on the front: 0VU = 1.228V = 7500Ω. @ 1000~. I really don't know if you can derive the Ampere value from this information.
And don't worry, I'm not sooo much in a hurry.
Old 14th July 2019, 03:34 AM   #34
ubergeeknz is online now ubergeeknz  New Zealand
Check the back. If nothing there you might have to derive it through measurement.
The Care and Feeding of Analog Meters | Nuts & Volts Magazine
Old 14th July 2019, 04:31 AM   #35
PRR is offline PRR  United States
PRR's Avatar
I'm not really sure how much µA my meter has....
200uA. We know this from the voltage, the (non-standard) resistance, the fact it is rated at 0VU while the scale goes to +3VU. Also it looks like they didn't use the last 10% of the range.
BUT this is probably an AC meter with internal rectifier. While the better plans above use a DC meter plus a rectifier, I'm not 100% sure it can be an exact swap. Maybe the ESR-meter gurus have insight.
Also: a working pro VU meter is worth much more than the type of $2 meter this project really deserves. (Sadly hard to find a $2 these days.)
Old 14th July 2019, 01:00 PM   #36
Elvee's Avatar
As PRR said, it is probably a 200µA AC, which is not suitable: I just tested a 200µA movement, but the circuit is incapable of supplying such a current, and it cannot be increased in a simple way, because of implications and constraints on other parts.
In addition, the internal rectifier could be selenium or similar, which is not suitable for 100kHz operation.
Depending on the internal construction, the actual, naked galvanometer might be more sensitive (because of scaling, half-wave rectification or similar cause).
If it is possible to dismantle it without risking damages (be super-careful!), you could see what is inside, and test the actual DC sensitivity.
Up to 100µA is manageable: I just did the test with a meter having 1K internal resistance and 6.8K series added.
It practically requires schottky or Ge diodes though: with ordinary 1N4148, the calibration remains possible, but the left of the scale becomes so compressed that it is not usable for more than 5 ohm.
Small Ge diodes are very common: all transistor radios used to have at least one.
There is an example of such a diode at the center of this picture:
Old 14th July 2019, 02:09 PM   #37
The old Midas console had 3 of the original VU-meters and 4 of smalles ones that at some point were installed to preplace the original ones.
On the attached pictures you can see that the replacing ones have a rectifier of 4 1N4148 diodes installed on the back, which can easily be removed.
Old 14th July 2019, 02:11 PM   #38
You will not be able to observe it, but the scales on both meters are the same.
Old 14th July 2019, 02:29 PM   #39
Elvee's Avatar
You can check the sensitivity of the small one using a fresh 9V battery and a 180K resistor (in series).
You do not even need to remove the diodes.
If it results in a full scale deflection, it is a 50µA.
If it's half => 100µA
1/4 => 200µA
You can try the same manipulation on the larger one: depending on the internal circuit, you could have a deflection -or not-.
Try both polarity: if it has a halfwave rectifier, only one will work
Old 15th July 2019, 03:12 AM   #40
The meters are all 200µA. I will check tomorrow to see if I have another one, hopefully 50µA...
Oscillator coil with common wires?Hide this!Advertise here!
Attaching flexible leads to aluminum voice coil wires cyclecamper Multi-Way 1 8th September 2014 06:17 AM
Commercial Pre-Pre Amps for Moving Coil Cartridges (MC Head Amps) in Common Base tiefbassuebertr Analogue Source 8 11th December 2012 08:54 AM
Is a Fuzz Face a common-emitter or common-collector circuit? ninopelo29 Instruments and Amps 6 9th December 2011 01:38 AM
glue for voice coil wires malcontent Multi-Way 5 6th March 2007 01:12 AM
Conductors (I.C.'s, RCAs, internal wires, speaker wires) bigphil Parts 1 25th November 2005 06:47 PM
Copyright ©1999-2019 diyAudio
