Equipment & Tools From test equipment to hand tools
Agilent/HP 82357B + HP 8903B + Pete Millett's tools / VEE runtime
Old 21st May 2019, 12:52 AM   #1
Rax is offline Rax  United States
Default Agilent/HP 82357B + HP 8903B + Pete Millett's tools / VEE runtime
Hi all,
Was wondering what Keysight/Agilent/HP VEE runtime program is everyone using under Windows 10? I can only get the VEE Pro 9.33 to install and it does seem to control the HP well, but I don't have $1k for this to be able to keep it past trial. This used to be free, as far as I know, and I'm just unsure what are the current options.
Secondly, is the Agilent/HP 82357B interface - which seems to be 100% genuine - supposed to come with the VEE program on it?
And, thirdly, any issues with Pete's tools running under 9.33? The VEE itself controls the HP perfectly well, but the programs were not doing anything. Just curious on the success rate there.
Thank you!
Old 21st May 2019, 02:37 AM   #2
tomchr is offline tomchr  Canada
tomchr's Avatar
I realize this isn't exactly the answer you were looking for, but in case you get stuck with your current solution, I suggest looking at the Prologix controllers. I have a brief blurb about them here: Neurochrome Audio :: Tools
I'd certainly rather spend $150-200 on one of those than throwing $1k after other tools. I used them to control my HP8903 and HP3562/63.
Tom
Modulus-86, 186, 286, 286 Kit, & 686: 40-240W (8Ω) at <-120dB THD.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 21st May 2019, 04:47 AM   #3
Tom
Tom - interesting... and thank you. I realize I came across your website and I also have looked at Prologix, but the missing link from my assessment of options is the arm+leg vs. free quirk of VEE today. I am pretty sure I should be able to return the Agilent GPIB module and get the Prologix without a ton of aggravation.
About that - are there any tools similar to Pete's available on this platform?
Thank you.
aR
Old 27th May 2019, 05:54 PM   #4
Tom - thank you again for picking up this conversation. A little more along the same lines.
Can your tools be ran with the Agilent interfaces? Not sure if there's a conspicuous "no" I should be aware of... The 82357B I have works perfectly fine with its included Agilent IO tools, and can fully connect with the HP 8309B.
Secondly, what are your tools returning? FR graphs, like Pete's? I am thinking of using the 8903B for this purpose, as I don't have a 3562A. As I have not yet explored the Prologix universe, I have no clue what is possible in that framework.
I can return the 82357B, but I don't yet feel I exhausted the exploration of what it can do. And the fact that it seems to connect so well with the 8309B makes me hesitant to return it yet.
Thank you for assisting with this.
Old 27th May 2019, 09:52 PM   #5
Jeez! KaboooOOooom! It's alive!
Thank you Pete - amazing guy he is - but there's both a Runtime (free) version of VEE, and the Pro ($2k) version. Running Pete's vxe code costs nothing and relies only on the free VEE program: VEE Runtime | Keysight (formerly Agilent’s Electronic Measurement).
Also, required were the following steps I found on the GBIP-USB Adapter google group (Google Groups):
1. Install Agilent IO Library [version].
2. After installing Agilent IO library, run Agilent Connection Expert, select tools-> Option -> Agilent 488 Option and check 'Enable Agilent GPIB cards for 488 programs'
3. Install Agilent VEE runtime [version].
4. Open IO Configuration under VEE runtime folder, select find instrument. If the 8903B is connected to your PC now, the default address should be 28, and the software will ask you whether send "*IDN?" to the instrument at address 28, select No because 8903B not recognize this command
5. right click on the new instrument(@GPIB0::28::INSTR) , select instrument properties, and change the name to Audio Analyzer (case sensitive here!!!).
6. Pressed the save I/O configuration button in the Instrument Manager (very important!!!)
7. Select Advance and change the timeout to 20 sec
Usually, this will make your 8903B works with Pete Millet's software. If you got error message as following:
"Configuration Error: Driver for "Audio Analyzer" not found error number 801
Use the instrument manager to add it"
Pls check step 5/6 and make sure you use the right name/GPIB address and saved the configuration
This is it.
Old 1st June 2019, 03:10 PM   #6
In case anyone wonders, current [version] is 9.33.
Old 1st June 2019, 04:11 PM   #7
tomchr's Avatar
No. The li'l script library I make available is specific to the Prologix controllers.
Prologix provides a USB/Ethernet-to-HPIB interface that you can talk to. That's it. You can send commands and get responses back.
My script library (MATLAB and python) will perform amplitude vs frequency and THD+N vs frequency sweeps and store the output in a .csv file. You can drag that into Excel for graphing.
I provide the library as-is, where-is with no promises of support (in fact, with promises of no support.... ). I don't have an 8903 anymore, so I can't assist in debugging.
I'd start with the python scripts. I've done all the hard work for you already. All you really need to do is to combine the building blocks I deliver to perform the function you need. If you've done any programming, python is pretty easy to learn.
If you want a more canned solution, you're better off looking elsewhere.
The advantage of the scripts versus a canned solution is flexibility. You could write a script to take your DUT through a complete test suite (many tests) automatically.
Tom
Agilent/HP 82357B + HP 8903B + Pete Millett's tools / VEE runtimeHide this!Advertise here!
SY/Pete Millett Crossover SY Tubes / Valves 111 1st May 2016 08:08 AM
HP 8903B and Pete Millett's Software Problem ? HP8903B Equipment & Tools 9 27th January 2016 10:00 PM
Pete Millett's Uniamp mr2racer Tubes / Valves 0 8th June 2014 05:20 PM
Pete Millett's Low Mu Preamp wirewiggler Swap Meet 2 28th May 2011 08:21 PM
Copyright ©1999-2019 diyAudio
