Equipment & Tools From test equipment to hand tools
120Hz hum in my amp, and here is a scope picture.
Thread Tools
Old 29th September 2020, 03:18 AM   #21
BSST is offline BSST  United States
BSST's Avatar
"Don't fix it if it's not broken" is my instinct. Generally, I can tell by looking at ripple with a 'scope if capacitance is insufficient.
Finding a defective solder joint is much more satisfying than a speculative replacement of caps which might not have exercised the bad joint.
Cheers!
Old 29th September 2020, 11:02 PM   #22
K-amps is offline K-amps  United States
In the end I had 4 newer caps laying around, plus the Original amp called for a massive bank, so I went ahead upgraded. Thanks all.
  Reply to this post
120Hz hum in my amp, and here is a scope picture.Hide this!Advertise here!
Thread Tools
Sources of 120hz hum? rntlee Tubes / Valves 4 30th January 2013 06:56 PM
Clear picture picture of KSS-273B eledora Digital Source 0 27th October 2007 02:10 PM
Great deal on Digital scope. Is this enough scope? hifimaker Pass Labs 1 1st May 2007 10:59 PM
heater voltage of scope picture tube ? Bernhard Parts 1 18th September 2005 04:03 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
